How Many Potlights In A 12x20' Room - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 02:03 PM   #1
How many potlights in a 12x20' room
My wife has moved her office/showroom to our front room/living room and there are no lighting fixtures in it at all. There is a switch that controls and outlet that we have a lamp plugged into but that's it.
The room has her desk in it which has a lamp (not enough light) and then she's got her stock cabinet (a large armoire) that I mounted some small halogen lights into for when she's got it open and pulling stock and she has a glass display case that I also mounted a single halogen in. These lights only get used for accent lighting.
The attic is right above her office so I can get access from above.
Now I'm trying to decide what kind of fixtures to use and how many.
I was considering (6) 5" recessed IC remodel fixtures connected to a dimmer and then turning the outlet into a regular/always energized outlet.
I once stumbled upon a site that let you enter room dimensions and fixtures and it would show you what the room would look like with the new lights but I can't find it.
Any ideas on how many lights I should be using? Breaker is 15 amps.
Mike
foolsfortune is offline   Reply With Quote
Old 02-19-2010, 03:34 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
however many looks good to you! is there anything else on the circuit? id also use remodel cans in existing ceiling
plummen is offline   Reply With Quote
Old 02-19-2010, 03:58 PM   #3
DIY staff
Rewards Points: 7,174
6 or 8 sounds about right. You might be happier with 6" cans---many more trims available.
Wider range of bulbs ,too.
Old 02-20-2010, 09:14 AM   #4
Rewards Points: 1,772
Try going to:
http://www.cooperlighting.com/conten...ion_guide5.cfm
some insights there.
bob22 is offline   Reply With Quote
Old 02-20-2010, 04:18 PM   #5
Journeyman Wireman
Rewards Points: 150
This site may be of use.
http://www.forteelectric.com/Howtolayoutcans.html
Jupe Blue is offline   Reply With Quote
Insulating a cold/well room? Lynch Building & Construction 23 07-25-2014 02:49 PM
Vents from boiler room RammsteinNicCage HVAC 3 03-11-2009 07:28 PM
Cold Room mikelbeck HVAC 14 01-16-2009 08:21 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
