How Many Outlets Exist On A Given Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2012, 03:45 PM   #1
How many outlets exist on a given circuit
Howdy,
I'm not an electrician, not going to do any electrical work. I'm trying to determine whether I need to have an electrician come in and add more circuits or if I can just be smart about my current resources. This is in an existing commercial building, that has had several remodels done to the interior. I want to know if we are under-wired (if thats the correct term). So the questions I have are:
1. Is there a way to determine what outlets exist on the same circuit without throwing the breaker and plugging something in to each outlet on the floor?
2. Is it watts or amps that I count for total consumption on a circuit to make sure I'm not overloaded? If so, how many of whatever measurement should I limit each circuit to?
Sorry if the nomenclature is bad. I'll try to clear up if I have misspoken.
gcdcpakmbs is offline   Reply With Quote
Old 01-11-2012, 04:02 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by gcdcpakmbs View Post
I'm trying to determine whether I need to have an electrician come in and add more circuits...This is in an existing commercial building...
commercial uses have a limit of # of outlets per circuit.
therefore... expect to add circuits is you need more outlets
1. Is there a way to determine what outlets exist on the same circuit without throwing the breaker... Not really.
2. Is it watts or amps that I count for total consumption on a circuit to make sure I'm not overloaded? watts/outlet @volts = amps
Old 01-11-2012, 04:23 PM   #3
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
What is the building being used for?
That would be the deciding factor for amount of power/number of plugs needed.
Last time i checked there was no minimum number of plugs required in a commercial room or bay other than a plug under service panel if thats all youre using
plummen is offline   Reply With Quote
Old 01-11-2012, 08:09 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
Originally Posted by plummen View Post
........... other than a plug under service panel if thats all youre using
A receptacle under a panel is NOT required. It's just very common.
Old 01-11-2012, 09:44 PM   #5
plummen's Avatar
Thats the fi8rst place our inspectors always look for a plug whether its an unfinished basement or an open bay,maybe its just the easiest/most obvious place to install one.
Best tools and efficient method for identifying outlets on a circuit, please. justplumducky Electrical 9 07-08-2012 09:27 AM
Do self grounding 110V receptacles really work? noquacks Electrical 50 05-25-2011 07:57 AM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 08:37 AM
