How Many Outlets Do You Recommend On 15A Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-02-2012, 02:00 PM   #1
how many outlets do you recommend on 15A circuit?
I've read enough to know that there is no hard and fast limit on the number of outlets on a single (residential) circuit. But, I've got one 15A circuit with about 15 outlets and another 5 lights. Most of the outlets are not used, and the ones that are, are only lightly loaded (all of the big stuff is on other circuits). But, it still seems excessive to me. What do you think?
Btw, this situation apparently exists due to rodent damage to the wiring (long before we moved in). It looks like one circuit went dead when a rat chewed thru the romex (that must've been exciting) and the dead circuit (not the rat) ultimately got connected to another live circuit. Anyways, there is an unused wire (currently wired for 240V, but I could change it) that could be used to split up the circuit. I'm just wondering how big of a deal this is, since I've always got more projects on the "to do" list than I can finish. Thanks.
Jeremy Hillary Boob, PhD is offline   Reply With Quote
Old 03-02-2012, 02:07 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
So you want to turn it into a MWBC and split it off for two circuits? Does it have two hots a neutral and a ground? You will also have to make sure the breaker feeding it is rated for the smallest wire gauge being used on the circuit.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-02-2012, 07:00 PM   #3
No, not a MWBC---got enough of them already. There is an unused circuit available, but it would be a bit of work to tap into it.
In any case, I'm just wondering if there is any sort of "rule of thumb" as to how many outlets you'd ordinarily put on one circuit. Thanks.
Old 03-02-2012, 07:37 PM   #4
rrolleston's Avatar
I think there is but I don't know it. You can't do anything with that 240 line unless you turn it into a MWBC.
Old 03-02-2012, 08:37 PM   #5
Master Electrician
Rewards Points: 3,750
There is no problem. Don't make one.
brric is online now   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
a7ecorsair (03-02-2012), Code05 (03-03-2012)
Old 03-02-2012, 11:20 PM   #6
The 240v has 14/2 wire, and was used to power an electric baseboard heater (recently removed and discarded). It's pretty easy to convert to 120v by simply moving the white wire to the neutral bar---I've already done one of these conversions in a different part of the house.
Anyways, the question I have is whether it is a good idea to have, say, 2 circuits, each with about 10 outlets, as opposed to 1 with 20. It seems to me that 20 is a lot. But, if this is relatively normal, I'll leave it alone.
Old 03-02-2012, 11:21 PM   #7
Thanks. That's 1 vote for "do nothing," which is among my favorite things to do...
Old 03-02-2012, 11:46 PM   #8
rrolleston's Avatar
If you are not tripping breakers I would leave it alone.
You could just convert that to 120 and put an outlet there. I thought maybe you had xx-3 wire. That would make use of the wire instead of snipping it off.
Old 03-03-2012, 12:12 PM   #9
Rewards Points: 240
Just from a convenience standpoint, it would be better if the circuit was split. Because if you ever have to shut it off for some reason, that disables a lot of the receptacles in your house. However, there is no limit in the NEC. (Canada is another story...) I'll throw in with the "if it isn't broke, don't fix it" crowd. Put it on your list of things to do if you ever need to open the wall up.
fa_f3_20 is offline   Reply With Quote
Old 03-03-2012, 12:13 PM   #10
When we first moved in, the breaker was tripping on occasion. Back then, we had to use some electric space heaters---now we've got a pellet stove (on a different circuit) so that's not an issue. I also put in a new outlet so that the television/game systems are on a different circuit. The way we use it, there shouldn't be any problem tripping the breaker.
I'll eventually convert the 240 to 120 (actually, I've got 2 of them), but for the time being, I've got bigger fish to fry.
Old 03-03-2012, 12:16 PM   #11
Thanks. Coincidentally, the drywall is off in several places at the moment---I'm in the destruction phase of a couple of projects. So, from that perspective, this might actually be a good time to consider tackling it...
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Best tools and efficient method for identifying outlets on a circuit, please. justplumducky Electrical 9 07-08-2012 10:27 AM
Do self grounding 110V receptacles really work? noquacks Electrical 50 05-25-2011 08:57 AM
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 03:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
