How Many Lights/outlets On One Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-11-2012, 08:35 PM   #1
how many lights/outlets on one circuit?
I have two questions.
In my shop I'm installing 10 8' florescent lights. ( they have (4) 4" 32w T8 bulbs per light). They will be wired to 3 switches, 2 switches will have 4 lights and 1 switch will have 2 lights. using 12-2 MC cable. Should I run each switch on a 20 amp breaker or will all of the lights be ok on a 20 amp breaker?
Outlets,
How many outlets can be on one branch? I have 15amp and 20amp outlets. I want to use both 15 and 20 amp breakers due to I have both and to use up.
Thanks in advance.
Arcmaster is offline   Reply With Quote
Old 12-11-2012, 08:45 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
There is no limit. You would have to check the amperage of the fixtures to determine if 1 or 2 circuits are necessary.
I'm guessing that each fixture is going to draw 1.5-2 A. I would put the lights on 2 15 A circuits.
As far as receptacles, again, it would depend on the equipment you plan on using. You can use 15A receptacles on a 20A circuit and you can use 20A receptacles on 15A circuits.
Dead circuit, couldn't find problem so tied into second circuit zappy12 Electrical 25 12-13-2012 09:38 PM
New circuit breaker owen22 Electrical 14 01-12-2010 07:08 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
