How Many Lights On A Circuit? How Many Outlets? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-12-2008, 10:32 PM   #1
How many lights on a circuit? How many outlets?
Hi everyone, I am doing my basement electrical and I need to know how many high hats (Halo cans) can be on one circuit? I am going to be using the 13 watt bulbs, but just in case in the future I want to put 65 watt bulbs to be able to dimm them. Also how many outlets can go on a circuit? No heavy loads, bathroom and laudry room are getting there own circuits and GFCI as well. Thanks
helpless handyman is offline   Reply With Quote
Old 04-12-2008, 11:02 PM   #2
joed's Avatar
Rewards Points: 11,506
If you are in Canada the limit is 12 device per circuit.
If it is lighting only on a 15 amp circuit then add up the maximum wattage allowed per fixture and don't exceed 1800 watts per circuit.
Old 04-13-2008, 11:42 AM   #3
Rewards Points: 58
You can put as many outlets on a circuit as you want. I am not sure about the lights. Good judgement usually prevails with this question. Remember not all the lights in every room will be on, just as not all receptacles will all be on. Now if you have teenage daughters, forget every thing I just said except the recepts.
J. V. is online now   Reply With Quote
Old 04-13-2008, 11:51 AM   #4
Rewards Points: 322
Something to consider when using a dimmer is the rating of the dimmer switch. If you wire all your cans on one switch, then switch to a higher bulb it will get too hot. I think the average is 600 Watts, but higher are available.
tribe_fan is online now   Reply With Quote
Old 04-14-2008, 01:11 PM   #5
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Use the maximum wattage listed for the fixtures. No more than 1800 watts on a 15 amp circuit and no more than 2400 watts on a 20 amp circuit for lighting circuits. Someone in the future may put the maximum rated bulbs in the cans.
Anyone wanting to try and use some 80% rule, please read 210.23 a and b and look at table 210.24.
jrclen is offline   Reply With Quote
Need a wiring diagram Mooreski Electrical 47 02-01-2015 04:07 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
Wiring Outlets Then Switch Then Lights heydj Electrical 9 05-07-2009 09:09 PM
Wiring for external lights and outlets MikeinBurien Electrical 4 12-05-2005 01:16 AM
? on 20A circuit / outlets / #of remhed Electrical 2 05-15-2005 09:55 AM
