Old 10-24-2009, 10:24 AM   #1
How many ground rods?
How many 8' ground rods should I install for a house in the country with plenty of acreage and no metal plumbing?
Roaddoggie is offline   Reply With Quote
Old 10-24-2009, 10:39 AM   #2
Xtreme DIY'r
Usually 2 ground rods are installed at least 6' between them
#6 min wire to connect to panel
Old 10-24-2009, 11:59 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
What are the ground rods for?
Old 10-24-2009, 12:09 PM   #4
I'm grounding two 200A panelboards, and plan to run #4 cu from each panel to the first rod with one continuing on to how many other rods I decide on. I've heard anywhere from two to eight rods but wondered what standard practice might be.
Old 10-24-2009, 12:28 PM   #5
Standard practice = two
220/221 is offline   Reply With Quote
Old 10-24-2009, 12:29 PM   #6
No ground rods are required by code.
If no forms of electrode exist, such as a metal underground water pipe, rebar in footings, or building steel, then a form of electrode is required to be installed.
Absent any other electrodes you can install a ground rod. If this rod does not meet the 25 ohms or less requirement (rarely even checked) then you can simply add another supplemental rod. Nothing more is required.
Unless a concrete encased electrode (rebar) is present most electricians simply sink two rods and are done with it.
Whoever told you you need eight rods is rather clueless.
Old 10-24-2009, 12:41 PM   #7
Bored today Petey?
A simple question deserves a simple answer.
Two
Old 10-24-2009, 01:05 PM   #8
Thanks, will install two.
Old 10-24-2009, 01:23 PM   #9
Sometimes yes, sometimes no.
You know me, if there is one simple answer I'll usually give it where others might elaborate excessively.
This is one area I don't like to be short and sweet. I like to give the correct answer. If someone asks how many ground rods are required the ONLY correct answer is NONE.
If there is a Ufer available WHY in the world would you install ANY ground rods????
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
How to properly test grounding system KE2KB Electrical 4 02-03-2009 11:59 AM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 11:12 AM
Temporary Genrator Ground theatretch85 Electrical 32 08-05-2008 01:05 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
