How Many Cables In A Hole? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2015, 07:44 PM   #1
Rewards Points: 664
How many cables in a hole?
I am replacing old cable and putting things on their own circuit etc, so I am in attic drilling holes in the top plate over the main panel. I do not want to drill too many holes in the 2 x 4, so I am wondering how many 12 ga. cables I can pull through one drilled 1" hole. Some of the holes appear to be only 3/4".
crescere is offline   Reply With Quote
Old 03-24-2015, 08:01 PM   #2
joed's Avatar
Rewards Points: 11,614
Not sure what code says but I wouldn't do more than 2. More holes won't hurt anything.
Old 03-24-2015, 08:25 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Bottom line is you can have up to four cables in a hole before you have to worry about anything.
Speedy Petey is online now   Reply With Quote
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
123pugsy (03-26-2015), gregzoll (03-24-2015), ront02769 (03-26-2015)
Old 03-24-2015, 09:33 PM   #4
Rewards Points: 664
The main panel is in the wall and the cables are coming up into the attic via two 2 x 4 top plates. I am concerned about putting holes in these top plates. Won't his weaken the 2 x 4s?
I have encountered this concern before.
Old 03-24-2015, 09:44 PM   #5
Rewards Points: 6,652
Only if you drill one continuous hole from one end to the other. You are over thinking this. Just make sure when you drill, that you are not going to drill into any electrical wiring on the other side.
Old 03-25-2015, 07:33 AM   #6
Rewards Points: 1,408
Speedy, as I recall from my 2014 code class, the instructor said only 2 cables per hole were now allowed. Offhand I don't know the section in the book.
John Grabowski
MrElectrician.TV
MrElectricianTV is offline   Reply With Quote
Old 03-25-2015, 07:46 AM   #7
This two cable limit is not accurate. After two you need to start derating. He is talking about the last sentence in 334.80.
With #14, 12 & 10 you do not need to worry about derating until you get to nine current carrying conductors, hence the four cable number. Neutrals of a multi-wire branch circuit do not count as CCC's.
240.4(D) limits the ampacity of #14, 12 & 10 considerably, and since we can derate newer NM cable from the 90 deg C column you get quite a difference between the two.
The Following 2 Users Say Thank You to Speedy Petey For This Useful Post:
gregzoll (03-25-2015), MrElectricianTV (03-25-2015)
Old 03-26-2015, 07:24 AM   #8
Rewards Points: 455
A 1" hole can easily take 4 wires of 12 or 14 or combination. We do it all the time, no inspectors ever said a word about it. 1" is a good size hole and 4 wires fit very loosely.
sparky90 is offline   Reply With Quote
Old 03-26-2015, 01:25 PM   #9
1" is a bit close with 2x4 framing. You don't have much room for being off center and staying legal.
Old 03-26-2015, 06:54 PM   #10
Rewards Points: 118
Not being an electrician, will nail plates take care of that off-center hole? Or is there yet another chunk of code covering drilling??
To the OP, don't think of taking a chunk of two bye four, supporting it over two others, drilling a bunch of holes in it and jumping up and down in the middle of it. Think instead of the overall load distribution of what is on top of it, the distance between supports and the strength of two boards them selves. Different story. ron
ront02769 is offline   Reply With Quote
Old 03-26-2015, 10:07 PM   #11
ront02769, that is why new construction you will see the main wiring trunk using 2x6 framing, so you can get around the issue with 2x4's.
You cannot use nailers, because the holes would be through the bottom & top plates. As for Vertical strength, you could just double the joists on either side, to help strengthen the area that would be pretty much cut away if it is a large amount of Romex.
Old 03-27-2015, 08:12 AM   #12
Rewards Points: 118
Missing your point. The metal nailing plate would go against the edge of the two bye plate keeping sheet rock screws etc. from hitting the wire.. That's how I've seen it done in residential work...but perhaps there is a specific guide that tells you where you. Can and cannot drill holes in two byes....like that six inch bye six inch prohibited space in the web at each bearing end of an i-joist?
Old 03-27-2015, 09:58 AM   #13
Licensed electrician
Rewards Points: 1,054
Nail plates are used any time the minimum 1.25" clearance cannot be maintained.
Two 2 pole 20amp breakers with just white wires connected to them. elec_2014 Electrical 36 11-01-2014 05:13 PM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 07:55 PM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 10:57 AM
Cutting out a hole on a stainless steel sink...pics Goldglv General DIY Discussions 14 02-28-2010 11:04 PM
How to patch hole in duct work and drill new one? Studly HVAC 10 03-03-2009 10:26 AM
