How Many Baseboard Heaters Can Be On A Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-24-2012, 09:01 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How many baseboard heaters can be on a circuit?
Just wondering. This house has 4 but we never use them.
Journeyman Plumber
Old 05-24-2012, 09:06 PM   #2
Licensed electrician
Rewards Points: 1,234
How many volts and watts are the heaters?
Old 05-24-2012, 09:17 PM   #3
Doing it myself
Alan's Avatar
I wish I could answer that, and i figured that would be the first response that I got.
I've tried looking for a data plate on them, but there isn't one anywhere that is accessible. Without removing the unit from the wall completely and checking the back and the bottom, I am at a loss.
Is it common to have multiple heaters on a circuit?
Journeyman Plumber
Old 05-24-2012, 09:23 PM   #4
I would not have a problem with multiple heaters on one circuit.
Typically baseboard heaters are 250 watts per foot.
For example a 4 footer would be 1000 watts. 1000/240 = just over 4 amps or just over 8 at 120 volts.
Old 05-24-2012, 09:29 PM   #5
Doing it myself
Alan's Avatar
Sounds like I am in the clear here then. Someday I would like to put in a heat pump system anyway.
Journeyman Plumber
Old 05-25-2012, 06:44 AM   #6
Rewards Points: 1,440
u could use a clamp on ammeter to measure the current draw. Use the same usual amperage ratings, such as 15 amps for 14 gauge wires, for either 120 or 240 volt heaters. The actual total draw must be 80% or less of the wire rating since heaters are "continuous" loads. The full wire rating is based on "intermittent" loads, things not expected to be drawing continuously for more than an hour or so.
AllanJ is online now   Reply With Quote
Old 05-25-2012, 08:39 AM   #7
The NEC defines continuous as 3 hours or more. Two hours 59 minutes, 59 seconds and off would be non-continuous.
electric baseboard heaters engraverlady Electrical 5 03-23-2012 06:06 AM
Kitchen circuit re-design - Existing is a mess darlingm Electrical 5 12-31-2011 10:45 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Removing hot water baseboard heaters. Sandy1000 HVAC 4 11-02-2008 05:41 AM
