How Many Amps Is The Service - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2013, 10:13 AM   #1
how many amps is the service
The main box on the outside of the house has two 100 amps old style tube fuses. The inspector says that that is 100 amp service and a contractor says it is 200 amp service. Which is it?
sc ott is offline   Reply With Quote
Old 09-16-2013, 10:25 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 386
100 amps.
Old 09-16-2013, 10:54 AM   #3
joed's Avatar
Rewards Points: 12,362
It is 100 amp service.
Old 09-16-2013, 11:01 AM   #4
Rewards Points: 126
Don't hire that contractor.
The Following 4 Users Say Thank You to J. V. For This Useful Post:
jbfan (09-16-2013), mpoulton (09-16-2013), Speedy Petey (09-16-2013), stickboy1375 (09-16-2013)
Old 09-16-2013, 02:54 PM   #5
Rewards Points: 358
definetly 100 amp, just because theres two fuses mean its 200 amps. sound like a really old service for fuses!
circuitman is online now   Reply With Quote
Old 09-16-2013, 04:17 PM   #6
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
What kind of contractor? Obviously not an Electrical type.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
jbfan (09-16-2013), Speedy Petey (09-16-2013)
Old 09-16-2013, 05:00 PM   #7
i suppose the transformer and service conductors could be sized for 200 amp but the fact that there are 100 amp fuses limits it to 100 amp.
itsnotrequired is offline   Reply With Quote
Old 09-16-2013, 05:44 PM   #8
dmxtothemax's Avatar
Rewards Points: 5,166
Isnt it 100a at 240v ?
And 200a at 120v ?
So it all depends on how you look at it !
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Philly Master (09-17-2013)
Old 09-16-2013, 06:03 PM   #9
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,180
And 200a at 120v ?
The service is 100 amps @ 240 volts. It is not rated at 120 volts.
That's like saying it is a 2 phase service because it has 2 hot legs 180 degrees out of phase from each other.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Old 09-16-2013, 07:23 PM   #10
Rewards Points: 1,192
Hot Legs ...Rod Stewart.
bobelectric is offline   Reply With Quote
Old 09-16-2013, 11:06 PM   #11
deverson's Avatar
Rewards Points: 77
Take a photo of the meter socket. That may bring the service down to a 60 amp service.
deverson is offline   Reply With Quote
The Following User Says Thank You to deverson For This Useful Post:
Moving service panel away from main service line entry k2000lbs Electrical 3 11-28-2011 08:39 AM
Need help on upgrading to 200 amp service drhard Electrical 9 10-31-2011 12:08 PM
Generator as sole power source NGuy Electrical 29 12-20-2008 12:29 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 08:39 PM
