How Many Amps Is My Sub-panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 12:57 PM   #1
How many amps is my sub-panel?
I have a sub-panel in my barn that is currently fed by a 60 amp breaker and the appropriate wiring. I would like to upgrade this to larger wire and 100 amp breaker, but I don't know the amperage of the sub-panel. How can I figure out how many amps the sub-panel will handle, and is it OK to use a 100 amp breaker with the appropriate size wire, to go to a lesser amperage sub-panel?
yellowdog5 is offline   Reply With Quote
Old 05-04-2009, 02:47 PM   #2
Rewards Points: 874
You need to provide a manufacturer and model number for your panel. No one can give you an answer without that info.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 05-04-2009, 04:13 PM   #3
If a sub-panel is only rated for 60a then you can't feed it with 100a
My panel has stickers on the inside that tell ratings
Old 05-04-2009, 04:48 PM   #4
FW
OK, it is a Zinsco, but I don't know how to find the model #. There is a UL numberA-4017. I am aware of the issues with Zinsco panels, but I do want to find out the amperage of this one, it is fed with #2 aluminum wire. Here are photos:
By yellowdog5, shot with Canon PowerShot A620 at 2009-05-04
Old 05-04-2009, 04:55 PM   #5
I forgot to say, I figured out that the sub panel is 125 amp, but the one in the above post is what feeds the 125 amp panel. I want to know if I can put more than a 60 amp breaker on the main panel.
Old 05-04-2009, 05:07 PM   #6
You can use whatever size panel you want.
The 60 amp breaker protects the 60 amp wire feeding the sub.
You cannot put a larger breaker on the 60 amp feeder wire.
Edit. I'm confused. Is the main panel pictured?
220/221 is offline   Reply With Quote
Old 05-04-2009, 05:23 PM   #7
Yes, the main panel is pictured. Can you tell me anything about it? It is fed by #2 aluminum wire and it has a 60 amp breaker. Can I use a larger breaker, or 2 breakers (a double pole 30 amp for the well and a double pole 60 amp for the sub panel?
Old 05-04-2009, 05:57 PM   #8
have you considered getting everything upgraded?
Paelectrican is offline   Reply With Quote
Old 05-04-2009, 06:06 PM   #9
joed's Avatar
Rewards Points: 12,328
The main panel/disconnect will need to be upgraded.
Old 05-04-2009, 06:09 PM   #10
IF YOU CAN TURN OFF THE POWER, you can easily replace the panel. Change it to one with a few more spaces.
And tape those neutrals white.
And tighten that locknut when you reinstall the conduit.
As far as running a bigger circuit to the barn sub (the conduit exiting the lower left?), you will need to increase wire size to get more amperage out there. To increase wire size, you will need to increase conduit size.
Old 05-04-2009, 09:15 PM   #11
And dont forget to De-Ox those existing aluminum conductors if you dont end up changing them!
Good eye on the locknut.
unclduey is offline   Reply With Quote
Old 05-05-2009, 04:54 AM   #12
[quote=220/221;269408]IF YOU CAN TURN OFF THE POWER, you can easily replace the panel. Change it to one with a few more spaces.
I can't turn off the power, that's why I'm asking all these questions. I think the #2 aluminum wire is the limiting factor. What is the maximum ampacity of #2 aluminum (type THW)? And my other question is how can I determine the ampacity of the panel pictured?
Old 05-05-2009, 06:14 AM   #13
Bigplanz's Avatar
Rewards Points: 960
Looks like you can go up to 90A
Ampacity chart.
http://www.cerrowire.com/default.aspx?id=46
Bigplanz is offline   Reply With Quote
Old 05-05-2009, 08:52 AM   #14
Thak you! 90A will suit my purpose just fine. Just to be on the safe side, does anyone else have an opinion?
Old 05-05-2009, 11:21 AM   #15
Once again, to clarify, you can put a larger breaker in to feed your sub panel but you have to upsize the wire and conduit also.
The breaker protects the wire.
Since you "can't" turn off the power, be very careful when removing/replacing the breaker. In fact, don't do it. Even I would hesitate doing it and I have decades of expeience, Things happen....like phase to phase explosions from old equipment.
I would say that (although illegal) you would be safer...more safe... by pulling the meter to kill power. That's what I would do.
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Generator as sole power source NGuy Electrical 29 12-20-2008 12:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 10:31 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
