How Many Amps For Garage Apt - Electrical - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 09:08 PM   #1
Rewards Points: 274
how many amps for garage apt
I am builing a detached garage and pulling electric off my 200 amp house electric (don't want a seperate meter) It will have a one bedroom apt, kitchen, bath, water heater, washer dryer. I want enough amps but not overkill because i am assuming the more amps the bigger the wire and more $$ it will take to run the 150' or so from house. I dont need a big compressor or heavy woodworking etc. in garage.
ugabulldog is offline   Reply With Quote
Old 04-09-2013, 09:22 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Will this be a legal apartment?
Old 04-09-2013, 09:25 PM   #3
Rewards Points: 274
yes, I forgot to mention it will have a mini split hvac sized for about 350 sq. ft.
Old 04-09-2013, 09:26 PM   #4
BIGRED
Rewards Points: 252
Will it be all electric or gas stove, water heater, and furnance??
Grampa Bud is offline   Reply With Quote
Old 04-09-2013, 09:35 PM   #5
You REALLY need to have a load calculation done, but from experience I'd say a 90 or 100A feeder is in order.
If this were just an apartment, you may get away with a 60A feeder, but even that is highly unlikely seeing as you'll have a laundry and electric (I assume) water heater, which would certainly be coincidental loads.
The Following User Says Thank You to Speedy Petey For This Useful Post:
ugabulldog (04-15-2013)
Old 04-10-2013, 08:12 AM   #6
Rewards Points: 274
all electric
Old 04-14-2013, 07:56 AM   #7
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Minimum 100 amp Panel ...
Philly Master is offline   Reply With Quote
The Following User Says Thank You to Philly Master For This Useful Post:
How can I check that a house cct can deliver 15 amps psommerfeld Electrical 26 12-03-2011 11:58 AM
Generator as sole power source NGuy Electrical 29 12-20-2008 01:29 AM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 11:31 PM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 09:39 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 08:13 PM
