How Many Amps Draw For These Small Devices. - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 10:23 AM   #1
Rewards Points: 99
How many amps draw for these small devices.
I would still like to have a general idea of the number of watts calculated for use by
1. stereo receiver
2. small (36") ceiling fan with 11 watt compact flouro bulb
3. smallest size dehimidifier
I am just looking for ballpark ideas, that why I haven't put in brand names etc.
Thanks for any tips.
Hossenfeffer is offline   Reply With Quote
Old 02-03-2011, 10:29 AM   #2
Experienced
Jackofall1's Avatar
1. stereo receiver - 100-2000
2. small (36") ceiling fan with 11 watt compact flouro bulb 11-20
3. smallest size dehimidifier - 200-500
Look at the amps multiply by the voltage, that will not be exact, but it will get you close.
Mark
Old 02-03-2011, 06:54 PM   #3
what he said,
If you have .3A and your are in the USA on a 110-115v then you have 33-34.5 Watts, if you have a way to measure the volts it may be higher, my house is 120-125v
if you have 3mA that's milli-Amps and is .003 Amps
now your receiver is hard to ball park, at idle they are low power, but if that thing is cranking out some tunes/5.1 surround it could easy hit 1000W peaks = 8.3 Amps or over half of a 15A circuit.
turbo v6 camaro is offline   Reply With Quote
Old 02-04-2011, 06:21 AM   #4
Inexpensive watt meters are available at home stores.
60 or 70 amps to small sub panel PIGEONS Electrical 10 11-23-2010 11:06 AM
Wire Gauges, Amps and Small Fixtures RedBear Electrical 1 11-06-2010 10:45 AM
Generator as sole power source NGuy Electrical 29 12-20-2008 12:29 AM
Calculating Amps draw for low voltage suprashy Electrical 6 09-16-2007 04:37 PM
Amps vs wattage moneymgmt Electrical 8 05-30-2007 07:13 PM
