#1 |
How many amps are delivered to the house's main panel?
Hi,
I have just purchased an older home (built in the late 50's), and it has had the service upgraded to 100 amp breaker panel a few years back. I would like to jump a sub panel out to the garage, but I am not sure how much amperage is actually coming to the house and how high I can go. Is there a standard for wire size coming to the house in Ontario, or does it change by region/builder? Thanks, Jim |
#2 |
Electrical Contractor
Since you have a 100 amp breker, then you have to assume that you have a 100 amp service.
Until the incoming wire size is verified, that is all you have to go on. You will not be able to pull more than the 100 amp main breaker.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett" |
#3 |
Master Electrician
You likely have upwards of 10,000 amps up to your house.
| The Following User Says Thank You to brric For This Useful Post: | Speedy Petey (03-15-2011) |
#4 |
It all depends on how much power the house is drawing.
But the fact that it was upgraded, suggests that is drawing a good amount. But is it drawing it at the same time as the garage ? Put in a small panel and see how it goes. Do you have some idea as to how much power you need in the garage ? And when you will be using it ? If it is needed at the same time as the house is drawing a good load. Then it is possible you will need an upgrade. |
#5 |
Ok let's re-word that question. Is there a standard wire size that will be used to run from the power lines to the house? Or does that change by region/builder/age of home etc?
Ideally I'd like to put 100 amps in the garage. I can easily see myself using in excess of 60 amps at a give time, at least for short periods of time. As of right now I have a lathe, milling machine, surface grinder, shop compressor, and likely a second compressor all running on 230 volt. As well as the plans to add welding equipment in the future, and the usual 115 volt stuff along the way. |
#6 |
I=E/R
60 amps is a lot of juice for a one man shop. If you need that much power you will have to upgrade your service at the same time.
#7 | |
Learning by Doing
How many amps are delivered to the house's main panel?Quote:
![]() Sounds like Jim might need it. We have 90 to our garage - but then again, we've got 200 at the house.
If I could only remember to THINK about what I was doing before I did it. |
#8 |
A 100 amp service will provide up to 100 amps on each leg! 2 legs X 100 amps = 200.
#9 |
Most folks find that #6 copper wiring and 60 amps (@ 240 volts) is enough for the garage. Nothing prevents you from running #2 copper (#0 aluminum) wires and putting in a 100 amp subpanel although you cannot make use of that much power in the garage without refraining from using any power back at the main house or putting in a larger e.g. 200 amp service.
The average homeowner who lost his house in the Oklahoma tornadoes should move for good and not rebuild. Too much complexity watchdogging the contractor. Too much a chance to be defrauded. |
#10 | |
#11 | |
100 amps per leg is still a 100 amp service.
#12 | |
#13 |
You talking to me?
why don't you just call the power company and ask them if the service drop is sized to carry what you need.
#14 |
How many amps are delivered to the house's main panel? |
#15 |
You talking to me?
I don't know how they do things in Canada but in my area, while there is standard sizes of wires for an installation, it is not unusual to find that the service drops were never upsized when a new larger service was installed. They like to leave what is there until there is a problem and then replace it. It's just like transformers. If the one there is big enough to feed 3 houses, if a 4th house goes in, it doesn't get changed. If 5 or 6 go in, it might not get changed. That is one reason the one at the end of my line caught fire one day. It was simply overtaxed and eventually died, in smoky flames.
| Display Modes | |
| new sub panel | BlueBSH | Electrical | 11 | 01-22-2012 09:28 AM |
| Main Panel / Service Upgrades | gbe | Electrical | 12 | 11-07-2009 12:20 AM |
| grounding of main panel and sub panel in older house | linkysys | Electrical | 2 | 10-01-2009 05:34 PM |
| Subpanel for now, convert to 2nd main panel later? | abmiller67 | Electrical | 2 | 08-27-2009 02:44 PM |
| Extending Old Main Circuit Panel | lkpowell | Electrical | 4 | 10-23-2008 03:15 PM |
