How Many Amps Is 10-2 Romex Safe For? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2012, 05:57 PM   #1
Rewards Points: 248
How many amps is 10-2 romex safe for?
length of up to 100 feet
jackwashere is offline   Reply With Quote
Old 10-24-2012, 06:00 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
I believe its 40.
Correction......30.
sublime2 is offline   Reply With Quote
Old 10-24-2012, 06:02 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
30 Amps, but I have to ask what you are using 10-2 for. It is an odd choice and doesn't have many uses.
Old 10-24-2012, 06:15 PM   #4
Rewards Points: 6,652
http://cerrowire.com/ampacity-charts
Old 10-24-2012, 06:43 PM   #5
Rewards Points: 248
Illegal 10x12. Caretaker cottage at a construction site while the main house is being built (but it will probably be used and stick around later). County says you can build whatever you want without forgiveness or permission as long as it's under 120 sq. ft. So I built a small 10x12 and next to it a 8x10 bathroom. I have a 120V 20 gallon water heater and a small space heater.
The choice was decided by the HD Supply manager. The wire was on clearance. I gave him some ridiculously low price for 250 feet. He agreed. It's outdoor wire. The only problem was getting it to go through conduit. Big headache! But that's already a done deal.
Old 10-24-2012, 06:59 PM   #6
If it is UF (Underground Feeder), you cannot run it in conduit, unless it is to protect going into a junction box on a wall. You are fine at 30 amps for 100 feet, but do not expect to run a microwave, tv, lights, room heater all at the same on a 110 volt circuit, if only 10/2.
Old 10-24-2012, 07:10 PM   #7
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
You can run UF in conduit, what you CANNOT do is wire a general purpose lighting and receptacle circuit to a 30A breaker, regardless if the wire is #10.
The Following 7 Users Say Thank You to Speedy Petey For This Useful Post:
electures (10-24-2012), frenchelectrican (10-24-2012), jbfan (10-24-2012), Jim Port (10-24-2012), jrclen (10-25-2012), mpoulton (10-24-2012), stickboy1375 (10-26-2012)
Old 10-24-2012, 07:11 PM   #8
NOT the best source for electrical advice.
The Following 10 Users Say Thank You to Speedy Petey For This Useful Post:
brric (10-24-2012), electures (10-25-2012), frenchelectrican (10-24-2012), gregzoll (10-24-2012), jbfan (10-24-2012), Jim Port (10-24-2012), jrclen (10-25-2012), Missouri Bound (10-24-2012), mpoulton (10-24-2012), stickboy1375 (10-26-2012)
Old 10-24-2012, 10:09 PM   #9
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
A perfect example.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 10-24-2012, 10:52 PM   #10
Semi-Pro Electro-Geek
Rewards Points: 2,928
You really should have 10-3, which would let you install a small subpanel to run whatever you need out there. A 30A 120/240V feeder would run a small water heater plus two or three general purpose 15A 120V circuits with no problem. But without that extra conductor in 10-3, you're limited to half the total load, and it's harder to set it up well.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-25-2012, 01:14 PM   #11
Rewards Points: 248
Grumble grumble! You're correct and yet that is exactly what I need to do.
So I guess I'll have to install a local load center with two breakers? To distribute the 30A into 20A and 10A cirucuits?
The Following User Says Thank You to jackwashere For This Useful Post:
Speedy Petey (10-25-2012)
Old 10-25-2012, 01:21 PM   #12
Licensed electrician
Rewards Points: 1,506
The smallest breaker you will find would be a 15 amp.
Old 10-25-2012, 01:23 PM   #13
jrclen's Avatar
Rewards Points: 514
20 and or 15. Yes, that is what you need to do. Those two breakers can add up to more than 30 as long as the #10 is protected by no more than a 30 amp at the source.
John
jrclen is offline   Reply With Quote
Old 10-25-2012, 03:32 PM   #14
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Wait to see what he says when he finds he also needs 2 ground rods for that sub
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Old 10-25-2012, 04:00 PM   #15
Rewards Points: 248
The 10/2 has a ground.
Help with Light Fixture - Braided Romex, possible Arc, is wiring safe? cntnick Electrical 5 03-17-2010 11:22 AM
Generator as sole power source NGuy Electrical 29 12-20-2008 12:29 AM
Cost Difference Between Conduit & Romex Shawns4 Electrical 39 08-25-2008 05:01 PM
Question about sharing nuetral (as in 12/3) wire Piedmont Electrical 19 01-22-2008 08:39 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 08:16 AM
