How Many 12 AWG Runs In A Piece Of 2" Sch. 80? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 06:52 PM   #16
DIYer
Originally Posted by chris75 View Post
Because he is asking if its alright to do what he wants to do, IMO if no codes are in order, then why ask if its okay?
He wants to know if it'll catch on fire, not what he needs to do to follow code. The two often coincide but not always.
For example a 25 inch nipple isn't going to be more of a fire risk than a 24 inch nipple but under the code it changes the rules completely.
Gigs is offline   Reply With Quote
Old 01-26-2009, 06:55 PM   #17
How long is the conduit?
Old 01-26-2009, 06:58 PM   #18
Electrician
So tell me this, how many cables is it before it does catch on fire?
chris75 is offline   Reply With Quote
Old 01-26-2009, 06:59 PM   #19
Cow
Did you read my code section? 312.5 (C) does not agree with you at all.
No I did not. It seems Exc. (g) kills that idea.
I only looked at note 2 to ch. 9, table 1 before responding. Live and learn. With that said, figuring cables the way the NEC wants him too, he's gonna need two or three 2" pipes for that. Time to get out the KO punch.
Cow is offline   Reply With Quote
Old 01-26-2009, 07:17 PM   #20
DIYer
That depends on a lot of things, but assuming he is using 20 amp breakers with his 12 gauge romex, I'd say he'd have a hard time putting too many in there.
From what he described it is just a sleeve after all.
Old 01-26-2009, 07:20 PM   #21
DIYer
Even if he were following the NEC, you have to follow derating but not fill on sleeves. With small Romex the fill calculation is what gets you.
Old 01-26-2009, 07:45 PM   #22
I am sure it isnt "as many as I can fit".
As many as you can comfortably fit.
220/221 is offline   Reply With Quote
Old 01-26-2009, 08:33 PM   #23
Maybe 5 feet long, and there is a 90 degree elbow at the end so the wires can more easily flow into the rafters.
mntnvew is offline   Reply With Quote
Old 01-26-2009, 08:39 PM   #24
Electrician
I give up, but do what you feel is right.
Old 01-27-2009, 08:30 AM   #25
joed's Avatar
Rewards Points: 12,892
Since it is longer than 24 inches derating applies. If you put more 9 current carrying conductors you need to derate the current carrying capacity.
But since don't follow the NEC as many as you can fit without damaging the cables.
Old 01-27-2009, 11:51 AM   #26
Question
If you were to drill holes in the sides every foot or so to ventilate the conduit, would that have any effect? I imagine NEC does not address something like that
Is derating due to just potential heat build up, or is it also the effect of current flowing on wires packed together?
Old 01-27-2009, 12:06 PM   #27
DIYer
Question
Don't do that.
Heat build up. Some heat is caused by the fields interacting and most by direct resistance.
Thing is, with 12 gauge wire the true ampacity is higher than 20 amps so you can derate it a good amount and still use it with 20 amps overcurrent protection.
Old 01-27-2009, 02:33 PM   #28
So for 12-2 you would hit derating at the 5th cable
Curious how many total cables & still have 20a capacity?
Old 01-27-2009, 03:26 PM   #29
Electrician
4 12-2's equals 8 current carrying conductors
After 9 current carrying conductors, then they start taking a hit.... Check out table 310.15(B)(2)(a), If you still wanted 20 amp capacity you could increase wire size.
#10 AWG is good for 40 amps as far as derating goes. THis would get you into the 10-20 Current Carrying Conductors at 50% value.
Old 03-02-2009, 11:27 AM   #30
Originally Posted by mntnvew View Post
Can anyone tell me how many 12/2 runs I can put into a piece of 2 inch schedule 80?
Thanks!
I got twelve (12) and the last one was a royal PITA!
small piece of floor needs carpet analogmusicman Flooring 4 11-08-2008 08:54 PM
PEX Manifolds: home-run to each fixture vs grouping runs? drh Plumbing 3 04-02-2008 03:44 PM
moving wiring runs in attic DoubleD07 Electrical 1 07-23-2007 06:44 PM
Remodeling upper...existing runs to the basement? wease Electrical 3 02-11-2007 10:49 AM
Removing single piece of siding shortagain Remodeling 4 01-02-2006 10:12 AM
