Old 11-09-2010, 09:00 PM   #1
How many 12-2 wires through one hole?
I'm wiring a small house that is built with metal studs that have the four elongated holes in them. I'm using the standard 1" grommets that will fit one above the other in each hole. How many 12-2 Romex wires can I run in each hole before I have to derate them? Thanks
Roaddoggie is offline   Reply With Quote
Old 11-09-2010, 09:23 PM   #2
" Euro " electrician
frenchelectrican's Avatar
Useally 3 X 12-2 NM cable thru 1 inch hole is not a issue.
Just make sure you have the groument ring secured in and when you pull the NM cable make sure they are not kinked up or twisted up.
Merci.
Marc
Removing wall with wires in it jboswald Electrical 11 11-29-2009 03:55 PM
Three hot wires coming into a receptacle? Jeff DIY Electrical 10 10-07-2009 02:35 PM
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 11 08-16-2009 09:06 PM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 07:01 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 03:55 PM
