How To Make A Shop Fan Variable Speed - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 07:08 PM   #1
How to make a shop fan variable speed
I have a 48" industrial shop fan that I need to slow down. It has a single speed 1/2 hp AC motor and I need to know what kind of motor I can put on it that will enable me to run the fan at half the RPM it now runs, and ideally, several slower speeds without giving up the capability of running it at full speed when needed.
lynndm is offline   Reply With Quote
Old 06-22-2012, 07:19 PM   #2
Rewards Points: 13,960
http://www.rockler.com/product.cfm?p...0&site=ROCKLER
Old 06-22-2012, 08:23 PM   #3
Rewards Points: 3,256
The best way to do this is to buy a 2 or 3 speed direct replacement motor and use a selector switch to control the speeds.
zappa is offline   Reply With Quote
Old 06-22-2012, 09:28 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,478
Electronic speed controls are readily available,
Purchase one suitable for your existing motor,
Easy as !
dmxtothemax is offline   Reply With Quote
Old 06-23-2012, 04:06 AM   #5
Any suggestion on where to buy such a motor? I have looked and come up empty.
Old 06-23-2012, 06:01 AM   #6
Well, I don't know your location or country but Grainger is the place to start here in the U.S. If you don't want to buy from there at least you will have a model number so you can search for other places to buy it.
Others have mentioned electronic variable speed but I don't think you will be happy with the performance on such a large fan. You will get it set to a speed that you want and then conditions will change causing the motor to speed up or slow down.
I switched out a single speed motor for a 3 speed on my 36" whole house fan years back and I mostly use low or medium speed.
Old 06-23-2012, 07:01 AM   #7
It has been a long time ago but I think I picked a similar motor in one of these links. My original motor mounted with a belly bracket attached to rubber rings on the front and rear of the motor so I simply swapped the motor out using the original mounting hardware. The long shafts can easily be cut if you are using belt drive but I can't remember if the motor I bought had a long shaft.
http://www.grainger.com/Grainger/DAY...er-Motor-4M100
http://www.grainger.com/Grainger/AO-...&cm_vc=IDPRRZ1
If you look in the belt drive or evaporator cooler catagory there are a number of 2 speed motors.
http://www.grainger.com/Grainger/hva...log/N-9xz?bc=y
Old 12-12-2012, 10:57 AM   #8
I have seen there are two different kind of motors, brushless (induction) and brush type. Each I think requites different type of speed controller - one being a VFD type.
Any ideas here??
tarnall is offline   Reply With Quote
Old 12-12-2012, 11:02 AM   #9
I believe most routers are a bush type motor and this speed control might work fine, but the 1/2 horse, washing machine, type motors are induction type motors, with this device work on these to slow them down? I have a drill press and a band saw with these type of single speed, 1750 RPM, that I would love to control the speed. VFD??? variable infrequence drive - do these come in small motor applications?
Old 12-12-2012, 11:08 AM   #10
Ole Wood Worker
BigJim's Avatar
Rewards Points: 488
If using one of the speed controls, it would be a good idea to check to see if the control will handle the amps the motor is pulling.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Replacing HVAC blower motor with a variable speed fan bkuritz HVAC 2 06-12-2011 11:33 PM
Are variable speed HVAC units worth the $$$? Jemo HVAC 9 05-07-2011 04:10 PM
Variable speed pumps and cycle control valves NHMaster Plumbing 0 02-25-2010 05:55 PM
Variable Speed Blower qnzkrew HVAC 2 01-03-2008 06:14 AM
3-way Ceiling Fan Dimmer? 47_47 Electrical 13 09-25-2007 09:31 AM
