Old 05-01-2011, 06:44 PM   #1
artlover13060's Avatar
How to make outdoor fountain safe?
I put in an outdoor fountain. The plug from the fountain is about 4' long. I currently have it plugged into an outdoor extension cord which goes to an outdoor plub. I know this is not the right way to do it. What do I need to do to make this safe?
artlover13060 is offline   Reply With Quote
Old 05-01-2011, 07:23 PM   #2
Electrical Contractor
Run uf cable from the receptacle at the house, and put one close to the fountain.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 05-01-2011, 07:34 PM   #3
Super Moderator
Make sure that the circuit is protected with a gfci outlet or breaker---just to be safe.
Old 05-01-2011, 07:34 PM   #4
joed's Avatar
4x4 post near fountain.
UF cable 24" underground protected at both ends with conduit where it exits the ground.
GFCI receptacle.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 05-01-2011, 07:52 PM   #5
Licensed electrician
These are nice and they don't rot.
http://www.arlcatalog.com/Weatherpro...in%20Cover.htm
Best way to make a roof exit or door? swaff Roofing 5 10-22-2010 02:15 PM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-22-2010 12:53 AM
Rewiring old house, Hit brace in outside wall, Safe to drill through Bottom Plate. twilightcall Electrical 2 06-30-2008 12:36 AM
Help Me.....installing Wall Safe shaw Carpentry 7 10-01-2006 05:50 PM
Make a cyclone fence safe for my pups not to dig out under it. dlpeterson@chartermi.net Introductions 4 07-27-2006 01:43 PM
