How Is It Looking So Far? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-17-2013, 09:24 AM   #31
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I prefer running my wire on a running board above the framing not below it in case they decide to finish it off and I put the boxes so they will be flush with drywall. I have a job coming up that someone else did and all the receptacle and switch outlets have to have extension boxes on them because they are flush with the framing and not the drywall.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-17-2013, 10:10 AM   #32
Roofmaster
Rewards Points: 2,172
1. The outlet boxes should extend out 1/2 inch beyond framing.
2. Why didn't you put a runner on top of the lower chord and staple the
wire to the top of the runner?
3. Why is there a hole in the end of the wire nuts with a ground wire coming through it?
4. There is too much sheathing left inside the boxes.
5. Conductors are not cut even at about 8 inches outside the box.
6. You should leave about 4 feet in the sub panel to neatly run the incoming wires.
Of course some of these are simply preferences, based on experience.
Old 04-17-2013, 01:09 PM   #33
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Originally Posted by Philly Master View Post
so in the example i used ...
unfinished basement ... concrete floor ..you use GFI outlets ... correct ...
The point is your opinion and the wording of the code are two different things here.
I have seen plenty of finished rooms with polished concrete floors, and the code makes NO mention of what is on the floor with regard to finished or unfinished.
Old 04-17-2013, 01:09 PM   #34
macon, ga bibb county
Rewards Points: 150
So I can use a metal box as long as the nm and mc have the correct clamp?
Lupus71 is offline   Reply With Quote
Old 04-17-2013, 02:05 PM   #35
jbfan's Avatar
Rewards Points: 138
Yes, and you bond the box.
Old 04-17-2013, 03:41 PM   #36
Oso954's Avatar
Rewards Points: 420
So you can attach the ground wire to the grounding screw(s), no pig tail required.
Oso954 is online now   Reply With Quote
Old 04-17-2013, 03:56 PM   #37
Philly Master's Avatar
Rewards Points: 516
what makes a room "FINISHED" ? in relationship to Electrocution ??
why do you need a GFI in a basement that is unfinished ....
do the walls and ceiling being finished with DRYWALL help the Electrocution hazards in any way shape or form ??
every other place that needs a GFI has a concrete floor or water.
210.8 (A) (2)
so when you read the CODE .... 210.8(A)(5) what makes it finished ??
( habitable ..LOL )
YES in IMHO ... the easy way is the floor finish ...LOL
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 04-17-2013, 04:16 PM   #38
rrolleston's Avatar
210.8 (A) (2)
( habitable ..LOL )
Here is the 2011 NEC code references I don't see anything requiring a finished floor.
210.8(A)(2)
(2) Garages, and also accessory buildings that have a floor
located at or below grade level not intended as habitable
rooms and limited to storage areas, work areas, and
areas of similar use
210.8(A)(5)
(5) Unfinished basements for purposes of this section,
unfinished basements are defined as portions or areas of
the basement not intended as habitable rooms and lim-
ited to storage areas, work areas, and the like
Exception to (5): A receptacle supplying only a perma-
nently installed fire alarm or burglar alarm system shall not
be required to have ground-fault circuit-interrupter protec-
tion.
Informational Note: See 760.41(B) and 760.121(B) for
power supply requirements for fire alarm systems.
The receptacles in a work area of a basement, as shown in
Exhibit 210.12, must have GFCI protection. Section
210.8(A)(5) does not apply to finished areas in basements,
such as sleeping rooms or family rooms, and GFCI protec-
tion of receptacles in those areas is not required. The only
exception to this requirement is for correlation with the per-
formance requirements covering fire alarm power supplies
contained in NFPA 72, National Fire Alarm and Signaling
Code.
Receptacles installed under the exception to
210.8(A)(5) shall not be considered as meeting the re-
quirements of 210.52(G).
Old 04-17-2013, 04:21 PM   #39
Rewards Points: 516
210.8 (A) (2)
( habitable ..LOL )
so you did not answer the questions either ...
Old 04-17-2013, 04:54 PM   #40
rrolleston's Avatar
Not trying to answer any questions just showing you the references you posted have nothing to do with floor coverings.
A finished room in building is insulated and Sheetrock walls and ceilings. I don't have a code reference with for it but I do know it does not take a floor covering to change whether a room is finished or not.
The Following User Says Thank You to rrolleston For This Useful Post:
Speedy Petey (04-17-2013)
Old 04-17-2013, 05:05 PM   #41
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
210.8 (A) (2)
( habitable ..LOL )
You do realize that most commercial buildings have concrete floors, right?
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 04-17-2013, 05:21 PM   #42
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Drywalled walls are my deciding factor.
The Following User Says Thank You to k_buz For This Useful Post:
Philly Master (04-17-2013)
Old 04-17-2013, 05:54 PM   #43
Rewards Points: 516
this is residential ...
commercial buildings do not require ACFi or tamperproof outlet either ...
Old 04-17-2013, 05:56 PM   #44
Rewards Points: 516
really how would you answer these two ...
Old 04-17-2013, 06:08 PM   #45
This is not being contested here. You implied that the whole "concrete floor or not" thing was a code requirement. It is not. Bottom line.
