How Is It Looking So Far? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 08:22 AM   #16
Rewards Points: 2,516
Originally Posted by joecaption View Post
Any reason why the boxes were not set so they stick out past the rafter?
At some point someones may well want to add a ceiling to make it eazyer to heat or cool and all the boxes would have to be set.
Also how do you plan on getting covers on them sitting like that.
Good catch.
hammerlane is offline   Reply With Quote
Old 04-16-2013, 08:24 AM   #17
Rewards Points: 150
As nice as your framing is, I'd insulate and drywall that in if it was my shop. And so, I'd have put in metal boxes. Then you can put on flat faces for now, or a mudring w 1/2" or 5/8" riser if someone drywalls later. I also would not have run the wires on the bottom of the board just cuz they might be in the way later. I don't see lights -- being a shop, should have lots of bright light? Just not to that part yet? Overall it looks good and clean. I miss NM.
SquishyBall is offline   Reply With Quote
Old 04-16-2013, 09:14 AM   #18
macon, ga bibb county
Rewards Points: 150
I think I left enough room for the plates to be flush with the rafter (I hope) it will be close. I have two 8' lights I'm hoping will provide enough light. If not i have 4 more 4' lights to help. I just was trying to keep cost down by running two big lights.
Lupus71 is offline   Reply With Quote
Old 04-16-2013, 04:28 PM   #19
Rewards Points: 150
I actually have about 75' of 14ga. Mc cable but im not sure if it is ran differently than nm. Can I run it like in the pics?
Old 04-16-2013, 05:29 PM   #20
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
Originally Posted by Lupus71 View Post
That's not a code issue though right? Do you know what I will need as far as gfci and afci? It's just a shop in the backyard. No plumbing or water.
Originally Posted by jbfan View Post
Gfci's for the receptacles and afci's not required.
all depends on what the FLOORING is .......
ie Basement if its concrete then GFI ... if its carpet then no GFI
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 04-16-2013, 05:34 PM   #21
Rewards Points: 516
we would have run the wires over top of the trusses .. since it is not accessable - can't walk
Old 04-16-2013, 06:24 PM   #22
Rewards Points: 150
The floor is just 3/4 advantech ply. I don't think code here would allow me to run across the open space of the trusses as you could hang tools or something on the wire.
Old 04-16-2013, 06:29 PM   #23
Master Electrician
Rewards Points: 3,874
Never heard that floor finishes are determining factors for GFCI protection.
brric is offline   Reply With Quote
The Following User Says Thank You to brric For This Useful Post:
Speedy Petey (04-16-2013)
Old 04-16-2013, 07:12 PM   #24
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Because it doesn't.
Old 04-16-2013, 07:13 PM   #25
E2 Electrician
This simply is not true....
The Following User Says Thank You to stickboy1375 For This Useful Post:
Old 04-16-2013, 08:00 PM   #26
Rewards Points: 1,298
I would make one suggestion...Those wires sticking out of the cieling boxes...take the ends of them and turn them up. One of the grossest job site accidents I ever saw was the result of the wires sticking down like that. The electrician was climbing a ladder to work on a box and stuck one right into his eyeball.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
Philly Master (04-17-2013)
Old 04-16-2013, 09:03 PM   #27
Rewards Points: 150
Geez, I'll do that. Good lookin out! How about the mc? Runs the same as nm but needs metal boxes? If so can nm be put into a metal box with mc?
Old 04-17-2013, 05:08 AM   #28
Rewards Points: 516
so in the example i used ...
unfinished basement ... concrete floor ..you use GFI outlets ... correct ...
now you are called to wire the basement because the customer is going to finish it .... and the floor will now be carpeted .... are you telling me that you make all the outlets GFI's ??? In the Finished area ?? i think not,, so why not ?? Flooring finish
Old 04-17-2013, 05:10 AM   #29
Rewards Points: 516
it's about the clamp that holds the wire .. NM and MC use different ones
Old 04-17-2013, 07:13 AM   #30
Licensed electrician
Rewards Points: 1,630
The inspectors I know would require more than a carpeted floor to consider the area as finished.
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
brric (04-17-2013), Speedy Petey (04-17-2013)
