How Is It Looking So Far? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-16-2013, 06:54 AM   #1
macon, ga bibb county
Rewards Points: 150
How is it looking so far?
You guys see any problems? Also after rough in do I have to use any gfci or afci recepticals or breakers?
Lupus71 is offline   Reply With Quote
Old 04-16-2013, 06:57 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
I don't see anything.
Old 04-16-2013, 06:58 AM   #3
Eventually you do.
Old 04-16-2013, 06:58 AM   #4
Rewards Points: 150
I drilled 7/8 holes in center of top plate as close as I could to center. Some may be off a little. I left about 2 feet hanging out of the sub panel.
Old 04-16-2013, 07:07 AM   #5
eastcoastsparky's Avatar
Rewards Points: 150
Is this going to stay unfinished living space
eastcoastsparky is offline   Reply With Quote
Old 04-16-2013, 07:10 AM   #6
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
It's done all the time, but I really hate metal staples on NM.
Old 04-16-2013, 07:12 AM   #7
Why is that?
The Following User Says Thank You to Speedy Petey For This Useful Post:
stickboy1375 (04-16-2013)
Old 04-16-2013, 07:12 AM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 142
3rd picture down, is that a yellow and white cable in the same box?
Old 04-16-2013, 07:16 AM   #9
k_buz's Avatar
Originally Posted by Speedy Petey View Post
Why is that?
The line is too fine between secured and damaging the cable. It's too easy to damage the sheath. I know, I know, we don't have to start debating.
The Following User Says Thank You to k_buz For This Useful Post:
Philly Master (04-16-2013)
Old 04-16-2013, 07:38 AM   #10
Rewards Points: 150
It will stay unfinished and it shouldn't be a yellow and a white if I remember correctly
Old 04-16-2013, 08:04 AM   #11
Master Electrician
Rewards Points: 3,682
Personally, my cables would be placed on the bottom chord of the trusses rather than on running boards.
brric is online now   Reply With Quote
Old 04-16-2013, 08:23 AM   #12
Rewards Points: 150
That's not a code issue though right? Do you know what I will need as far as gfci and afci? It's just a shop in the backyard. No plumbing or water.
Old 04-16-2013, 08:28 AM   #13
Rewards Points: 2,512
No water or plumbing? Then its not a shop just a structure.
And if you do not have a fridge of beer it is not even a structure, it is a prison.
Looks good though.
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Old 04-16-2013, 08:53 AM   #14
Rewards Points: 12,858
Any reason why the boxes were not set so they stick out past the rafter?
At some point someones may well want to add a ceiling to make it eazyer to heat or cool and all the boxes would have to be set.
Also how do you plan on getting covers on them sitting like that.
Old 04-16-2013, 08:55 AM   #15
jbfan's Avatar
Rewards Points: 142
Gfci's for the receptacles and afci's not required.
