-   -   How is it looking so far? (http://www.diychatroom.com/f18/how-looking-so-far-177269/)
Lupus71 04-16-2013 05:54 AM
You guys see any problems? Also after rough in do I have to use any gfci or afci recepticals or breakers?
Speedy Petey 04-16-2013 05:57 AM
I don't see anything. :huh:
Speedy Petey 04-16-2013 05:58 AM
Eventually you do.
Lupus71 04-16-2013 05:58 AM
4 Attachment(s)
Attachment 69218
Attachment 69219
Attachment 69220
Attachment 69221
I drilled 7/8 holes in center of top plate as close as I could to center. Some may be off a little. I left about 2 feet hanging out of the sub panel.
eastcoastsparky 04-16-2013 06:07 AM
Is this going to stay unfinished living space
k_buz 04-16-2013 06:10 AM
It's done all the time, but I really hate metal staples on NM.
Speedy Petey 04-16-2013 06:12 AM
Why is that?
jbfan 04-16-2013 06:12 AM
3rd picture down, is that a yellow and white cable in the same box?
k_buz 04-16-2013 06:16 AM
Originally Posted by Speedy Petey (Post 1160295)
Why is that?
The line is too fine between secured and damaging the cable. It's too easy to damage the sheath. I know, I know, we don't have to start debating.:whistling2:
Lupus71 04-16-2013 06:38 AM
It will stay unfinished and it shouldn't be a yellow and a white if I remember correctly
brric 04-16-2013 07:04 AM
Personally, my cables would be placed on the bottom chord of the trusses rather than on running boards.
Lupus71 04-16-2013 07:23 AM
That's not a code issue though right? Do you know what I will need as far as gfci and afci? It's just a shop in the backyard. No plumbing or water.
hammerlane 04-16-2013 07:28 AM
No water or plumbing? Then its not a shop just a structure.
And if you do not have a fridge of beer it is not even a structure, it is a prison.
Looks good though.:thumbsup:
joecaption 04-16-2013 07:53 AM
Any reason why the boxes were not set so they stick out past the rafter?
At some point someones may well want to add a ceiling to make it eazyer to heat or cool and all the boxes would have to be set.
Also how do you plan on getting covers on them sitting like that.
jbfan 04-16-2013 07:55 AM
Gfci's for the receptacles and afci's not required.
