How Long Is Safe To Run Low Voltage Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-15-2012, 09:35 AM   #1
Rewards Points: 308
How long is safe to run low voltage wire?
We live on three acres of land with the house many yards from the road. I would like to add some low-voltage up-lighting to our entrance--unfortunately, however, there is no electricity down that way. My thoughts are that mounting a transformer on the side of the house and burying low-voltage wire all the way down to the road would be more cost-effective than having electricity ran down that way. Is this safe? Or are there other options I should explore? I already tried solar LEDs--they just do not put out enough light. Thanks in advance!
smokey847 is offline   Reply With Quote
Old 06-15-2012, 09:43 AM   #2
Licensed electrician
Rewards Points: 1,892
You will have an issue with voltage drop over long distances. It would be better to run line voltage and install the transformer close to the load.
Old 06-15-2012, 10:11 AM   #3
Rewards Points: 6,652
Solar powered with a deep cycle marine battery to hold the charge.
Old 06-15-2012, 10:21 AM   #4
Rewards Points: 826
You can run low voltage but as stated by others it is not perfect as the distance grows.
1) LED Landscape stuff is starting to show up, not as plentiful as incandescent but improving daily. The lower power will reduce the voltage drop issues.
2) Some commercial landscape transformers have multiple voltage taps so you can send, say 15VDC at the transformer, so by the time it gets to the first fixture it is 12V.
http://www.landscapelighting.com/ope...pe/15PR600.pdf
3) The problem with 2 is when a bulb burns out the voltage will rise and stress the remaining lamps more. This might be acceptable.
4) You can do a combination of #2 and heavier gauge wiring to address the voltage drop if it is very long.
5) I couldn't find one but I wonder if someone makes a landscape transformer with remote voltage sense. You run 12-14 AWG wires for the lamps and then say 18-20 gauge wires for a DC voltage feedback and the transformer regulates voltage to keep measurement point at 12VDC. Would seem an obvious feature (and pretty easy to do) but I couldn't find one. This would stop the issue of voltage bouncing around as bulbs burn out.
curiousB is online now   Reply With Quote
Twisting wire for higher voltage Calrob77 Electrical 15 06-07-2012 07:59 PM
efficiency voltage drop wire gauge jackwashere Electrical 6 02-18-2012 08:33 PM
Adding ground in old home ChaosTheory Electrical 6 06-16-2010 04:02 PM
Tying in aluminum wire to copper wire...legal? safe? I_think_I_conduit Electrical 2 11-06-2009 05:38 PM
Voltage on my grounding wire fgordon1 Electrical 3 02-02-2009 07:58 PM
