How To Know/test If An Outlet Is GFI Protected (water Test Doesn't Work)? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 05:41 PM   #16
I=E/R
a7ecorsair's Avatar
Originally Posted by Red Squirrel View Post
The water test will be hit and miss because the ground, hot and neutral is submerged so chances are there that all current just goes straight to the neutral and not through the ground.
As stupid as this test is, it won't trip a GFCI if a two wire extension cord is used and the bucket is plastic and isolated from a good ground. There would be no leakage current.
a7ecorsair is offline   Reply With Quote
Old 03-07-2011, 05:45 PM   #17
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Yeah you'd need to use a 3 prong, and isolate the neutral. Can probably shove some caulk in there or something and make that extension cord a GFCI tester.
Not that I'd recommend it though, but it would work.
The test I said with the bulb is a bit safer. Put the ground in first, then just touch the hot with the other wire.
Best to just buy a real tester though.
Old 03-07-2011, 06:38 PM   #18
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
...........Best to just buy a real tester though.
Nuff said
Off Topic, but my problem was analyzing GFCI nuisance trips so I made my own Tester
Disclaimer
& Stay Safe
.....Bob Lavery
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
