How To Know If You Have A 20 Amp Circuit - Electrical - DIY Chatroom Home Improvement Forum
Old 05-11-2011, 09:44 AM   #1
How to Know if you have a 20 amp circuit
I am considering buying a commercial grade treadmill that has the following power requirements: 120 Volt/20 Amp Dedicated (NEMA 5-20 Receptacle)
Is there anyway to quickly check to see if I have any 20 amp dedicated circuits. If I need installation I will call a professional--I just want to know what I have before I bring someone in.
Thanks for the feedback!
sitkasassy is offline   Reply With Quote
Old 05-11-2011, 10:05 AM   #2
I=E/R
a7ecorsair's Avatar
Unless there was some special requirement from the past, I doubt if you have a dedicated 20 amp receptacle and in most cases you won't even have 20 amp receptacles. A 120 v 20 amp receptacle will have one slot that looks like a sideways T. If it is a dedicated circuit it would be a single receptacle instead of a duplex.
a7ecorsair is offline   Reply With Quote
Old 05-11-2011, 10:59 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
to the most basic portion of your question of how do you know if you have a 20 amp circuit:
you look at the breakers in your breaker panel. If there is a "20" on the handle, it's a 20 amp circuit.
as to one being dedicated; almost guaranteed you do not have a dedicated 20 amp circuit. A dedicated circuit of any amperage rating would typically only be installed if needed. Unless the previous owner of the house just happened to need a dedicated 20 amp circuit in the same area you need one, there is not going to be one available for your use.
The Following User Says Thank You to nap For This Useful Post:
Leah Frances (05-11-2011)
Old 05-11-2011, 11:02 AM   #4
Rewards Points: 256
You probably don't have a dedicated circuit.
I make an electrcal map of every house I buy.
I get a friend with a tester in every plug, and flip breakers till it goes off.
If I blow a fuse, I look at my labels, or blueprint, and I instantly toggle the correct one.
Doing this exercise will let you know if any circuit is dedicated.
Other than refrigerator or specialty appliances like a welder, big tablesaw, treadmill, or window a/c, you don't have a dedicated circuit.
The cheap way to get a dedicated circuit is to find a 20amp circuit with nothing but a couple outlets on it and simply don't use the other outlets when you use the treadmill.
michaelcherr is offline   Reply With Quote
Old 05-11-2011, 01:02 PM   #5
Rewards Points: 512
Unless a handyman did the wiring, in which case it could be a duplex
Old 05-11-2011, 01:15 PM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Then technically it wouldn't be a dedicated circuit.
Kyle
Old 05-11-2011, 05:09 PM   #7
Master Electrician
Rewards Points: 3,866
Sorry, we install dedicated circuits all the time with duplex receptacles. For instance, refrigerators.
brric is online now   Reply With Quote
Old 05-12-2011, 12:52 AM   #8
Rewards Points: 512
Then, unless the Duplex was split, this wouldn't count as a dedicated circuit, as defined by NEC 100:
Branch Circuit, Individual.
A branch circuit that supplies only one utilization equipment.
Old 05-12-2011, 05:32 AM   #9
Master Electrician
How is a duplex receptacle, behind a refrigerator, suppling more than one utilization device?
Old 05-12-2011, 06:34 AM   #10
Just call me Andrew
Rewards Points: 1,020
I don't think you understand what a "dedicated circuit" is. All it means is that you have a breaker in your panel that ONLY controls one thing, in this case an outlet that your treadmill will plug into. Since the previous owner did not likely have a high-powered electrical device that required a 20A dedicated circuit, the chances of you having one that is available for use is very low.
Andrew
secutanudu is offline   Reply With Quote
Old 05-12-2011, 08:07 AM   #11
joed's Avatar
Rewards Points: 12,854
A NEMA 5-20r has one slot that is sideways. If you don't have any receptacles like that then you don't have the circuit you need.
Old 05-12-2011, 01:35 PM   #12
Rewards Points: 512
You must know that the possibility exists for the duplex to be used to plug in a microwave, or anything else that the unlearned may desire.
A dedicated circuit, to me, is one which has a single receptacle.
Old 05-12-2011, 04:44 PM   #13
Master Electrician
I believe your interpretation is wrong, but I understand your thinking.
Old 05-12-2011, 05:31 PM   #14
licensed electrician
This isn't true, we install duplex recepticals on dedicated circuits all the time. Just because it's a duplex or a quad even doesn't mean it isn't a dedicated circuit.
The Deez is offline   Reply With Quote
Old 05-12-2011, 05:44 PM   #15
nap
You talking to me?
nap's Avatar
does anybody have the NEC on their computer?
If so, please look for anything referring to a "dedicated circuit"
To my interpretation of the term and lacking any direction from the code otherwise, a dedicated circuit is one that is established for a specific use. I often suggest people provide a dedicated circuit to certain areas of a home such as where they will place an entertainment center. I suggest a double duplex or even 2 double duplexes be installed on that dedicated circuit. I know that every time I have installed a dedicated circuit for a fire alarm panel or the phone companies equipment, not only did they not care if there was more than a simplex recep, in the case of the phone company, they require either a duplex or even a double duplex.
Need a wiring diagram Mooreski Electrical 47 02-01-2015 03:07 PM
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 09:04 PM
Home Theater Dedicated Circuit rjschwar Electrical 20 12-16-2009 12:42 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 06:46 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
