How To Isolate Outlets From Main Light Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 08:45 AM   #1
How to isolate outlets from main light switch?
Hi folks!..Just bought a house built in 1989. The main light switch in the living room also controls power to all 4 oulets in the the living room....hate the setup. How can I make all 4 outlets "hot" regardless of the light switch position?...
jtrom is offline   Reply With Quote
Old 10-10-2012, 08:58 AM   #2
Licensed electrician
Rewards Points: 1,248
The code requires at least one switch controlled receptacle or lighting outlet in that room. You need to leave at least 1/2 of one receptacle switched.
Old 10-10-2012, 09:05 AM   #3
joed's Avatar
Rewards Points: 11,992
Tell us the wiring in the receptacles. It might not be possible.
Old 10-10-2012, 09:26 AM   #4
Thanks, I will check out the outlet wiring and post it later. What is the reason for a code regulation like that?...just wondering
Old 10-10-2012, 09:28 AM   #5
They don't want people walking into dark rooms.
Old 10-10-2012, 09:53 AM   #6
Rewards Points: 52
Notice what Jim said, and, if you haven't done so, go back and check both receptacles at each location. You may find that all of them are split, providing you with one switched and one unswitched receptacle at each location; an ideal situation in my opinion.
Old 10-10-2012, 10:18 AM   #7
In the duplex receptacle, is one receptacle switched and the other powered all the time? If yes, keep the first receptacle as is. You will need to replace the other receptacles because they have side tab between the two brass screws is broken/snipped like in the below image.
In the other three boxes, only connect the constant hot, neutral, and ground to the receptacle. Cap off the switched hot.
brgmgb is offline   Reply With Quote
The Following User Says Thank You to brgmgb For This Useful Post:
jtrom (10-10-2012)
Old 10-10-2012, 10:35 AM   #8
That would be great if they were all split. I never thought of that, thanks for the heads up. Sounds too good to be true, though.
Ceiling fan - Light on dimmer switch, Fan on normal switch renderflux Electrical 3 09-10-2012 02:36 PM
Light switches and outlets stopped working. jeweladdict Electrical 4 08-13-2012 11:51 AM
Looking for a special light switch for task lighting shazapple Electrical 3 01-02-2012 10:39 PM
Light switch installation problems pc_clone Electrical 8 11-30-2009 10:25 PM
Bedrooms have no ceiling light, light switch controls one electrical outlet? notenoughtime Electrical 16 05-25-2009 01:09 AM
