How To Install This Shoplight? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-26-2010, 03:49 PM   #1
how to install this shoplight?
Hi everyone, first time poster here. I don't know much about home diy, and my dad mostly does woodwork around the house as a hobby.
My dad bought this light fixture from a thrift shop of sort and he doesn't know how to install it. All I know is it uses a ballast p. I've taken some pictures and hopefully one of you experts can tell us what's going on.
Problem:
There's no plug coming out of the fixture so how do we get power into it? Also, how do we find out what kind of bulb it uses. Thanks in advance.
Shot at 2010-09-26
Shot at 2010-09-26
Shot at 2010-09-26
senna is offline   Reply With Quote
Old 09-26-2010, 06:14 PM   #2
best guess is white from supply connected to two white wires twisted together (no wire nut currently) and black from supply connected to blacks currently joined by yellow wire nut. Ground from supply to housing where green wire attaches.
oberkc is offline   Reply With Quote
Old 09-26-2010, 07:35 PM   #3
Just call me Andrew
Rewards Points: 1,020
I agree with oberkc.
Andrew
secutanudu is offline   Reply With Quote
Old 09-26-2010, 07:37 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Those guy hit the the spot however let me add one more comment here make sure you secured the ballast otherwise you may have issue like noise and very poor grounding as well { the golden rules with ballast is never float them } and check the tombstone connections to make sure they are good and tight you can wiggle it.
If it came out just push it back in.
Merci,
Marc
Old 09-27-2010, 06:50 AM   #5
Rewards Points: 1,548
Since you don't have the instructions that may allow you to, do not fasten the fixture directly
to the wall or ceiling. Instead hang the fixture from chains or otherwise leave a few inches of
space so air can circulate around it and keep the ballast inside from overheating.
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 08:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 06:29 PM
