How To Install An Outlet To A Light Bulb Fixture. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 02:39 AM   #1
How to install an outlet to a light bulb fixture.
Okay so we have a garage with a light bulb fixture and a light switch in this garage nothin else.
Is it possible to connect a power point to the light fixture instead of the light bulb fitting?
The switch for the light bulb has only 2 wire going to the switch, I am not sure how many wire the light fixture has.
If this is at all possible, how would one go about fitting the new power out let?
Any information will be great thanks regaurds Enforcefx
enforcefx is offline   Reply With Quote
Old 10-17-2011, 06:53 AM   #2
Licensed electrician
Rewards Points: 1,622
Based on your spelling of reguards I am going to guess you are not in the US?
Old 10-17-2011, 08:08 AM   #3
joed's Avatar
Rewards Points: 12,904
Since the switch has only two wires if you want a receptacle then you must connect it to the light fixture box. How you connect it depends on if you want it switched with the light or always on.
Tags
how to fit a power point
Adding additional light fixture to switched circuit woodardhsd Electrical 5 07-07-2011 09:06 PM
Removing old light fixture & install ceiling fan sjk Electrical 3 04-17-2011 08:32 AM
Could a older light fixture cause premature CFL light bulb failure? imola ghost Electrical 10 01-10-2010 03:53 AM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
