How To Install Nutone Fan/Light/Nightlight - SKIP The Nightlight? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 10:08 PM   #1
How to install Nutone Fan/Light/Nightlight - SKIP the nightlight?
Hello, I have a new Nutone Fan/Light/Nightlight that I am installing. However, we're not ready to run the new wire for the nightlight so I want to leave that out of the wiring for now.
I have a Black/White/Red/Grd coming in and on the housing I have Blue/White for the LIGHT, Red/White for the Nightlight and Black/White for the Fan.
Any ideas?
Fan and documentation are here:
http://nutone.com/product-detail.asp?ProductID=11880
mike.ober is offline   Reply With Quote
Old 11-04-2011, 10:16 PM   #2
Licensed electrician
Rewards Points: 1,018
Just leave the lead fo the nightlight inconnected.
Old 11-04-2011, 10:28 PM   #3
That makes sense - guess I'm just being extra careful.
I think I end up doing the following.
White to White (fan) and White (light)
Black to Black for the fan
Red to Black for the light
Ground to green
leave the red/white pair for the nightlight disco'd
Make sense?
Old 11-04-2011, 10:34 PM   #4
Makes sense.
Old 11-05-2011, 05:00 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 812
Mike....you have potential....
You asked a 'decent' question....and gave good information...
A nice change from the recent spat of DIY questions that makes you wonder what they are smoking....
ddawg16 is online now   Reply With Quote
Old 11-05-2011, 05:53 AM   #6
Electrical Contractor
kbsparky's Avatar
CONNECT the night-light together with the regular light. Install a bulb in both sockets.
Then, when the regular light bulb burns out, your night light can provide a minimal amount of light until you replace the main bulb.
-KB
New cabinets, subfloor & install height Ohming Building & Construction 10 03-02-2011 03:18 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Diagonal Hardwood Install Advice JDeFuria Flooring 7 06-29-2009 04:35 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
