Old 07-28-2012, 01:28 PM   #1
Lightbulb
How to install LED strips to a Lutron dimmer with Magnetic transformer
Hey guys, first post here....
I have been making DIY vids for my LED business and come here for advice, but have never posted. I want to share this install video. Hope you like it!
http://www.youtube.com/watch?v=19LW6ZGeTmA&hd=1
Rziegler is offline   Reply With Quote
Old 07-28-2012, 04:20 PM   #2
Master Electrician
I do a ton of this sort of installing in my line of work. Two issues I see is the fact the your romex isnt in an approved connector at the switch location( this doesn't apply for the low voltage side). And secondly you need to have access to the driver. Otherwise it looks pretty good. I actually just put in about 500 feet of LEDs almost the same as the one shown in the video.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 07-28-2012, 04:23 PM   #3
Master Electrician
What's the output wattage on the driver. How many feet of LEDs is it good for. Also good to note that on the load side of the driver a lot recommend that you not go any farther than 30 feet or so until your connection point at the lights.
Old 07-28-2012, 07:40 PM   #4
A "Handy Husband"
rjniles's Avatar
No NM connectors on the NM going into the switch box. Metal switch box not grounded. Transformer (which is also a junction box) buried in the wall.
Coastal South Carolina
rjniles is offline   Reply With Quote
Tags
dimmable, dimmable switch, led strip lights, lutron, under cabinet
Help with simple dimmer switch install nikeman Electrical 10 11-08-2010 11:10 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
door bell transformer install? THEBIGPUNN Electrical 2 09-09-2010 08:01 AM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 10:44 AM
dimmer switch circuit wiring stan_d_bballman Electrical 2 11-17-2007 12:44 AM
