How To Install LED Power Supply For Strip Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 09-11-2014, 11:11 AM   #1
Rewards Points: 1,668
How to install LED power supply for strip lighting
I'm looking at using two of these led bars:
https://www.superbrightleds.com/more...Specifications
The longest one is rated at 960 mA. I need two, so about 2 A.
On this page, a number of power sources (need 12 v):
https://www.superbrightleds.com/cat/...ttage,6,84,25:
I don't see an easy way of permanently installing the light bars' power supply. Do you just use low voltage staples and build a little shelf or something to hold up the transformer? It seems like it would similarly go against the logic of permanently using an extension cord.
My 120v AC source will come from an existing 4" round box that the existing single bulb light originates from.
Thanks for any suggestions.
bob22 is offline   Reply With Quote
Old 09-11-2014, 01:03 PM   #2
Master Electrician
Rewards Points: 3,920
The posted links are not correct.
brric is online now   Reply With Quote
Old 09-11-2014, 01:07 PM   #3
Sorry,
I hope these are better links:
https://www.superbrightleds.com/cat/rigid-light-bars/
https://www.superbrightleds.com/cat/...ower-supplies/
Portable 120v power supply Question oblivius General DIY Discussions 6 05-29-2014 03:56 PM
Restoring Power Supply tonystip Electrical 5 08-20-2013 01:52 AM
No power too lighting in Master bedroom, hallway and bathroom(also fan) wackyned Electrical 15 11-09-2012 10:19 AM
Installing track lighting no power when screw in bulb keebs45 Electrical 8 03-18-2012 01:48 AM
Undercabinet lighting power source? Ideas? PDubs Electrical 7 01-28-2009 04:37 AM
