How To Install IKEA Ceiling Light - Electrical - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 07:15 PM   #1
how to install IKEA ceiling light
I purcahsed the IKEA Kroby pendant light. The light has a black wire, white wire, green/yellow wire, and two silver wires. In the ceiling there are only two wires, a white wire and an orange wire. What do I connect to what? Thanks!
kyliec123 is offline   Reply With Quote
Old 11-16-2010, 08:25 PM   #2
Did it come with instructions? Unfortunately, I could not find them online.
Are the silver wires insulated or bare? Are you able to identify voltages in your house wires? Does your house wires include a bare copper wire in addition to the white and orange?
oberkc is offline   Reply With Quote
Old 11-17-2010, 07:52 AM   #3
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Black & White is your Hot & Neutral. All the IKEA lights I Have had the green as ground.
Do you have a multimeter? If not, $10 at Harbor Freight and it's one of the most frequently used tools I own, use it to test which wire in your ceiling is the hot one.
CoconutPete is offline   Reply With Quote
Old 11-17-2010, 11:49 AM   #4
Any idea what the "silver" wires are? Grounds also?
Old 11-17-2010, 12:40 PM   #5
Rewards Points: 504
Not a clue actually ... are you sure they are not just "safety chains" in case the fixture lets go?
Old 11-17-2010, 03:04 PM   #6
Rewards Points: 256
I have no experience with ikea lights, but most fixtures have a braided metal wire.
You can connect that to the box(ground screw if no green wire on fixture) or anywhere really since there is a seperate green.
This allows the fixture to hang while you attach the wires.
The orange wire will likely be your hot, but i'd get a testor to confirm.
The green wire of the fixture won't do much since your wiring isn't grounded.
Attach it to the bare wire(if it were there)
michaelcherr is offline   Reply With Quote
Old 11-17-2010, 07:38 PM   #7
" Euro " electrician
frenchelectrican's Avatar
If OP live in Chicago area then orange conductor is switched hot conductor.
But for two silver wire can you post a photo to make sure we are on right page.
Merci,
Marc
replace ceiling fan with ceiling light pglc General DIY Discussions 11 06-08-2009 06:12 PM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
Help with wiring an Ikea ceiling light hlong2 Electrical 4 03-15-2008 04:22 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 10:30 AM
