How To Install An Electrical Outlet In The Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 07-29-2009, 09:39 PM   #1
How to install an Electrical Outlet in the basement
I have a basement storage room, and i was wondering how you would install another outlet in the different rooms. (there is already one outlet down there) Is it hard to install on? And what do i need to do it?
Thanks!
Riley W is offline   Reply With Quote
Old 07-30-2009, 02:39 PM   #2
Is it hard to install one?
That is a relative question.
1. The proper wire
2. Proper tools
3. Proper knowledge.
Before any useful advice can be offered, you need to do some research and come back with specific questions alaong with the details of your proposed project.
You need to understand the basics of your electrical system and decide where you are going to get the power (closest source?...new circuit from the panel???)
After that it's a matter of figuring out which materials to use and what methods you will use to install them.
Or just call someone.
220/221 is offline   Reply With Quote
Old 07-30-2009, 02:51 PM   #3
Have you done any electric work in the past?
That helps decide how easy this is
What size is the existing circuit, size of the wire?
How far are you running the new outlets?
Wood studs, steel studs, just concrete walls?
Different rooms - finished unfinished ?
Is the existing outlet GFCI protected?
Electrical outlet in a vanity drawer hdbdave Electrical 12 08-19-2012 11:27 AM
Electrical outlet & Ceiling fan mike-ee Electrical 1 04-28-2009 07:33 PM
Outlet install in Cabinet? jamiedolan Electrical 5 09-28-2008 01:35 AM
Basement outlet rough wiring tigerbalm2424 Electrical 4 12-31-2007 03:20 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
