Old 01-11-2012, 10:07 AM   #1
how to install device box
I feel really stupid asking this question, but how do you install this device box to a wood stud?? Am I missing something here? Could it be that the device box is meant for rework?
There are two holes on each of the sides near the back, but the box ends up crooked when I use those holes.
Take a look at the pic and let me know what you think. Thanks!
spaz619 is offline   Reply With Quote
Old 01-11-2012, 10:20 AM   #2
Missouri Bound's Avatar
Depending on the application, you need either an old work box, or a box with a bracket for new installations. That box is an "add on box" The side is removable so you can create a longer box using more of the same type. It's not what you want to use.
Old 01-11-2012, 10:22 AM   #3
MarginallyQualified
Originally Posted by spaz619 View Post
...but how do you install this device box to a wood stud?? You don't.
Am I missing something here? Yes.
99.987% of residential work will use ROMEX wire and plastic boxes.
The most common new work plastic box is the "nail in". Get some.
Old 01-11-2012, 10:22 AM   #4
Just call me Andrew
Yeah, that type of box requires metal straps and is meant to be mounted to existing drywall. You want a "new work" box, and if you have nm (romex) cable, it can be plastic:
Andrew
secutanudu is offline   Reply With Quote
Old 01-11-2012, 10:23 AM   #5
Just call me Andrew
You beat me, tarheel.
Andrew
Old 01-11-2012, 10:25 AM   #6
Do plastic boxes come in 1 1/2" deep?
Homedepot only seems to sell the metal ones in 1 1/2"
Old 01-11-2012, 11:03 AM   #7
Licensed Pro
That box is mounted by driving nails through the holes in the sides, entering one side, passing through the box, and exiting the other side. It is intended for new work only.
Old 01-11-2012, 11:17 AM   #8
MarginallyQualified
Do plastic boxes come in 1 1/2" WIDE?
Homedepot only seems to sell the metal ones in 1 1/2" WIDE
Print out that picture and take it with you to the store.
You'll find them. (Look low for the big boxes at floor level)
Old 01-11-2012, 06:35 PM   #9
Licensed electrician
You may be able to find that box with a side bracket that could screw to the stud.
Old 01-11-2012, 07:38 PM   #10
Master Electrician
Use the box you have with 2 16 penny nails through the holes in the box driven into the stud.
brric is offline   Reply With Quote
Old 01-11-2012, 08:19 PM   #11
Electrical Contractor
kbsparky's Avatar
See pic
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
brric (01-11-2012)
Old 01-11-2012, 08:21 PM   #12
On some occasions I have removed one side plate, and driven screws through the holes at the rear of the box, then replaced the side plate.
Aprilaire 560 Install Questions MisterTFM HVAC 4 12-15-2011 01:35 PM
Help with new construction window install pac127 Windows and Doors 1 09-26-2011 09:36 AM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 03:29 PM
Fiberock install STUPID Flooring 5 10-16-2007 07:29 PM
