How To Install Ceiling Fan When No Electical Box - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 07:52 AM   #1
how to install ceiling fan when no electical box
I want to install ceiling fans and the ceilings have no electical boxes. How do I install them. There is no way to run the electical threw the ceiling.
needhelp2451 is offline   Reply With Quote
Old 08-11-2012, 07:57 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If there is no possibility of running new wires, you will need to install a surface mounted raceway EMT, or Wiremold. You will still need to mount a fan rated box to a framing member to hang the fan from.
I'm guessing you live in an apartment.
Old 08-11-2012, 08:05 AM   #3
framing member
what is a framing member
Old 08-11-2012, 08:14 AM   #4
k_buz's Avatar
Call an electrician or your landlord.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (08-11-2012)
Old 08-11-2012, 08:46 AM   #5
Conduit, wire, permission from landlord, etc.
I don't know you and am not trying to make you feel bad or be a smart *ss.
Based on your 2 posts, it does not sound like you can handle this task. Call an electrician.
parman is offline   Reply With Quote
Old 08-11-2012, 08:47 AM   #6
Rewards Points: 13,458
There's always a way to run the wiring, cal an electrition and he will show you how it's done.
Old 08-11-2012, 10:01 AM   #7
Master Electrician
Could be condo. Painted slab. Either way its going to have to be surface.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-11-2012, 02:17 PM   #8
Rewards Points: 3,130
Red flag, or what??
Old 08-11-2012, 03:03 PM   #9
Bill Kearney
Rewards Points: 1,174
You need a box to hold the wires and give the fan someplace to be mounted. Boxes can be added. But it depends on what kind of ceiling is involved. Wires will have to be run to it, presumably from somewhere else and involving a light switch.
When questions this simple get asked it's not uncommon to have people tell you to call an electrician. This is GOOD advice and should be taken seriously. If you get it wrong the wires could short out and start a fire. Or the fan could fall down and seriously injure or kill someone.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
oh'mike (08-11-2012)
VERY Quick Ceiling Fan install question! Fox Electrical 11 03-23-2014 12:56 AM
Trying to install self stick vinyl tile on ceiling but it doesn't stick buggy Tiling, ceramics, marble 2 01-27-2012 05:50 PM
Install New Work IC Recessed Cans in an Old Ceiling Sierevello Electrical 3 02-03-2011 01:01 AM
Sagging ceiling timbo59 Drywall & Plaster 8 07-02-2010 12:15 PM
How to install resilient channel on ceiling Bcoleman6 Building & Construction 1 08-22-2008 02:29 PM
