Old 07-30-2011, 09:28 PM   #1
How to install a ceiling fan w/o a ground
I live in a very old numerous additions home and when taking the old light fixture down there was no ground wire in the ceiling! Now what?
karebear09 is offline   Reply With Quote
Old 07-30-2011, 11:33 PM   #2
It will be alright. Just ground the new fan to the box
jmans8666 is offline   Reply With Quote
The Following User Says Thank You to jmans8666 For This Useful Post:
karebear09 (07-31-2011)
Old 07-31-2011, 12:03 PM   #3
J. V.'s Avatar
It will be alright but not right.
Old 07-31-2011, 02:38 PM   #4
But if your house is older wiring without a ground its fine
Old 08-01-2011, 09:17 AM   #5
Smile
The ground was invented for possible lightning strikes to the house. This rarely happens. Those in areas where it is highly likely should have their wiring updated. But for now hook the black wire to the black wire and white wire to the white wire. Either cut the ground off or screw it to the electic box. These days boxes are made of plastic and are not grounded so it would do no good to ground it to plastic if it is not grounded. Being grounded means that the electric box has either a ground wire running all the way back to the breaker box that has a ground that is grounded with a grounding rod or having metal boxes that are grounded with metal conduit that has a ground connected to this metal.
ernie_the_dog is offline   Reply With Quote
Old 08-01-2011, 10:31 AM   #6
I=E/R
a7ecorsair's Avatar
If you are going to comment on the GES, OK. If you are going to comment on the EGC, OK. Don't mix thing up....
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Jim Port (08-01-2011)
Old 08-01-2011, 11:08 AM   #7
Just call me Andrew
As a7ecorsair said...you are missing a huge part to this. The EGC is to trip the breaker if there is a ground fault. This has nothing to do with lightning.
Andrew
secutanudu is offline   Reply With Quote
Old 08-01-2011, 05:14 PM   #8
Never cut a wire off just cap it
Old 08-01-2011, 08:48 PM   #9
Semi-Pro Electro-Geek
Allow me to add onto this dogpile: You don't understand the difference between grounding and bonding. Grounding is what you describe. Bonding is the more important function of "ground" wires to equipment. The purpose is to ensure that the metal parts of the equipment cannot become electrified by a ground fault in the equipment. If a hot conductor shorts to the metal frame, the breaker will trip immediately because the metal is bonded to the system neutral through the "ground wire".
mpoulton is offline   Reply With Quote
Tongue and Groove Ceiling install....questions... Dr. Jim Remodeling 9 04-08-2012 01:14 PM
newbie attempting ceiling fan install batman Electrical 4 04-18-2011 07:54 PM
Install New Work IC Recessed Cans in an Old Ceiling Sierevello Electrical 3 02-03-2011 02:01 AM
VERY Quick Ceiling Fan install question! Fox Electrical 10 07-02-2010 05:03 PM
240 volt load/appliance and ground vs neutral kgize Electrical 7 04-23-2010 12:40 AM
