How To Install A 100 Amp Subpanel - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 07:56 PM   #31
Rewards Points: 18
I just had a conversation with a local electrician that will view my project soon and he recommends using Aluminum # 4, with 4 wire cable to feed my sub-panel? He also would use the 60 amp double pole breaker in the main panel as we were planning to use. I have been looking at the 6/3 NM-B cable to use as a feeder cable. Not sure what the difference between copper and aluminum is? I guess there is a cost savings? Would you recommend using copper or aluminum? Just curious of what is the general practice. Thanks again.
AdamsBurr is offline   Reply With Quote
Old 06-07-2011, 09:40 PM   #32
I ask the impossible!
Rewards Points: 712
I don't know the prices on the smaller sizes like that, but let's put it this way. The difference between copper and aluminum for my 30' garage feeder at 100 amps was the difference between $100 and $360.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 06-07-2011, 09:47 PM   #33
Rewards Points: 18
Was the $100 for aluminum and $360 for copper? The electrician told me the aluminum # 4 was $1.25 a foot. The 6/3 NM-B was $2.00 a foot. Is aluminum as good as copper or is it not worth the savings? How about safety?
Old 06-07-2011, 09:54 PM   #34
Missouri Bound's Avatar
Aluminum is just as good as copper. The difference is the ampacity for the same size wire as you already know. The service to your home is aluminum.
Old 06-08-2011, 08:00 AM   #35
Rewards Points: 18
Thanks again for all of the support with this project, I appreciate it. I had to refresh my memory and took another look at the ampacity chart. Looks like #6 copper and # 4 aluminum are rated the same. So if I use copper #6 or aluminum #4, it will give me exactly the same ampacity and should be plenty to feed my sub-panel. And I would be able to save some money on the wire, which is always a good thing.
correct garage subpanel wiring lawsklsux Electrical 14 11-14-2010 10:54 PM
60 amp subpanel install mshaw2 Electrical 14 10-27-2010 09:05 AM
Have questions about adding a 60amp subpanel humberguy Electrical 6 05-13-2010 07:57 AM
Surface Mount subpanel and 110/220 recepts - good idea? vsheetz Electrical 4 11-15-2009 10:29 PM
Another subpanel question:) primal65 Electrical 15 06-22-2008 09:43 AM
