How Increase The Length Of Wire To Line Connection - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 11:56 AM   #1
Question
How increase the length of wire to line connection
I need to extent the wires on a power supply in a luminaire so that they reach the supply voltage in a remote junction box. They are 14g stranded copper. Can I solder on wires with the additional length I need and then use shrink tubing around the joint or do I have to use wire nuts or both.
Thanks,
Dale
wdrrob is offline   Reply With Quote
Old 08-02-2011, 12:01 PM   #2
Rewards Points: 150
Google "vinyl insulated butt splices"
Broughton is offline   Reply With Quote
Old 08-02-2011, 12:32 PM   #3
Rewards Points: 79
Thanks,
Dale
You can't hide junction points in the wall. Butt splices or any other kind of splice you may use. You need a junction box and it has to be accessible.
CheapCharlie is offline   Reply With Quote
Old 08-02-2011, 01:09 PM   #4
Rewards Points: 150
That is a good point. Thank goodness multiple people look at these posts!
Old 08-02-2011, 01:12 PM   #5
Ok. That's what I figured. All of this will be done in an aluminum enclosure that contains the PS and and is accessible. So the next question is, what defines a junction box?
Old 08-02-2011, 01:58 PM   #6
Rewards Points: 6,652
A metal, plastic, or fiberglass box rated for the use in electrical circuits. Also a old sub or main power panel without the guts can be used as a junction box.
Old 08-02-2011, 02:05 PM   #7
Rewards Points: 1,580
Is this going to be inside or outside (the junction for the splice)? If outside, you need a junction box and wire rated for wet exposure. Other questions come to mind regarding how you are running the new wiring to the light (surface or behind walls, floors, etc) and if it needs to be protected from damage?
bob22 is offline   Reply With Quote
Old 08-02-2011, 02:27 PM   #8
joed's Avatar
Rewards Points: 12,852
Just use wire nuts. No need for but splices and crimpers.
Old 08-02-2011, 04:12 PM   #9
This is an outdoor canopy light. I'm disconnecting the Universal ballast/caps from the line voltage so that I can wire in a PS that will run LED lights to replace the metal halide. The PS comes with only 6" of wire but is rated to be IP67 and is mounted near to the LED modules. Currently, the line in is wire-nut connected to the ballast but there's no specific junction box so I assume the canopy enclosure must qualify as such.
Old 08-02-2011, 04:30 PM   #10
Is this new fixture outdoor rated? Post a picture of the old & new light you are wanting to use in question, along with any website info if avail. Keep in mind, LED lighting may not be as bright as a Metal Halide would be.
3 wire stove connection bgoldie Electrical 13 03-01-2011 12:29 PM
wire connection peteracki Electrical 6 05-18-2010 06:12 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
How do I find my Line length for building trusses? missfixit Building & Construction 8 03-12-2009 05:13 PM
3 wire connection for new kitchen stove rjniles Electrical 4 09-13-2007 12:59 AM
