How To Include A GFCI Outlet With Multiple Loads - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 10:20 AM   #1
How to include a GFCI outlet with multiple loads
We are rewiring our bathroom to include a GFCI outlet so that other receptacles in the bathroom are on a GFCI circuit.
So here's what we have:
Vanity Light (currently connected to one switch)
Light above the tub (currently connected to the same switch)
Exhaust Fan (currently connected to the same switch)
Kitchen Exhaust Fan (kitchen and bath are beside each other - currently connect to the outlet)
What we would like to do is use a dual switch where one switch will be for the Vanity Light and Light above the tub. The other switch will be for the exhaust fan. The GFCI outlet will be used as such and will protect all receptacles in the bathroom. And the kitchen exhaust fan wired to the outlet. There is one power source feeding all these currently and they are all on one breaker on the panel.
I would like to know how to wire so that we can have all receptacles protected by the GFCI. If a picture would help let me know.
Thanks.
Gwennr is offline   Reply With Quote
Old 10-13-2010, 10:29 AM   #2
joed's Avatar
Rewards Points: 11,976
Since this is a rewire your receptacles in the bathroom can not be on the same circuit as the kitchen fan. The receptacle must also be a 20 amp circuit. The bathroom lights and fans can remain on the circuit. If you move the kitchen fan to a different circuit then all the stuff in the bathroom can be on the 20 amp circuit.
Old 10-13-2010, 10:34 AM   #3
Ok so we'll remove the kitchen fan from the circuit. No problem. I know the power source needs to connect to the Line on the GFCI but how do we connect the wires from everything else so that they 'feed' from the Load?
Old 10-13-2010, 10:39 AM   #4
Licensed electrician
Rewards Points: 1,236
The GFI has two sets of terminals; LINE and LOAD. Anything connected to the LOAD terminals is protected by the GFI.
Old 10-13-2010, 10:47 AM   #5
Just call me Andrew
Rewards Points: 1,020
Usually lighting does not need to be GFCI protected. The tub light MIGHT need protection, but might not. Depends on the light.
Might be a good idea to connect at least the vanity light to the LINE (unprotected) side of the GFCI. This way if it trips, you are not left in the dark.
Andrew
secutanudu is offline   Reply With Quote
Old 10-13-2010, 11:31 AM   #6
I'm with you. But I can't seem to wrap my mind around how to connect everything together. Can't get a picture to upload. I need to know how to connect the wires (pigtail or otherwise) from the lights and fan so that they connect to the correct switches and are GFCI protected .
Nevermind - we figured it out. Thanks for all your help.
How to wire in GFCI outlet from scratch? hellothere123 Electrical 5 04-25-2010 11:43 PM
Another puzzling question about GFCI outlet Giles Electrical 3 02-20-2010 02:00 PM
15 amp gfci outlet on a 20 amp circuit? Jeremy Hillary Boob, PhD Electrical 3 11-28-2008 08:05 PM
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 09:17 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 09:38 PM
