Is This How I Wire A 240v Timer? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-23-2009, 04:46 PM   #1
Rewards Points: 410
Is this how I wire a 240v timer?
Yozit, I know you mentioned I'd save a few cents getting a timer but 8.8kW each time a particular situation arose at 23 cents/kw that's a couple bucks each time the situation happens, occuring around 50 times a year I think the $28 timer worth it (but I also don't expect to save $100/year with it either).
The timer I'm looking at (Intermatic WH21) install instructions are at
http://www.intermatic.com/~/media/fi...20english.ashx
Is my drawing of how to wire it correct (I used Red but the true wire is white)? I'm used to these timers having their motor run on 120v and require a white neutral to the bus bar, and usually only one leg goes to the timer and the other to the load. The instructions give me the impression the motor runs on 240v and it wants both lines even though only one is switched. Anyway, does my wiring diagram match the install instructions?
Thanks!
Piedmont is offline   Reply With Quote
Old 04-23-2009, 05:54 PM   #2
I wouldn't use that timer. It appears that it doesn't disconnect both legs. It may be legal but if you get a double pole timer it can serve as your disconnect also by turning off both legs.
Intermatic T 104 is about $35 I think. When you pull the guts out you can turn it over and see exactly how it works.
220/221 is offline   Reply With Quote
Old 04-23-2009, 07:45 PM   #3
Idiot Emeritus
Rewards Points: 1,492
That's the kind of timeclock I'd recommend as well. Not very expensive, and pretty much bullet-proof.
They usually have 40 amp contacts, just make sure to get one with a 208-240 volt clock motor.
I've had better luck with the mechanical ones than the electronic ones.
The mechanism of a brand new one will usually fit in a box thats 40 years old. They had a winner, and stuck with it.
Rob
micromind is offline   Reply With Quote
Old 04-23-2009, 09:16 PM   #4
The T104 and the WH40 look like they have the same design and specs with DPST the WH25 however only has a SPST. So I would go with the T104 or the WH40
hayewe farm is offline   Reply With Quote
Inline timer for 240v 30A? Piedmont Electrical 11 04-22-2009 05:37 PM
240V Electric Heater install - 3 wire vs. 4 wire? dhgarage Electrical 7 12-12-2008 10:49 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 09:00 PM
