How Horrifying Is This? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2012, 03:43 PM   #1
How horrifying is this?
I live in an old farm house; and may have to explain to the home owner, about why I tore out the flood lights!
We have an old shed out back with a light, switched from the main house. The power is fed from the main house, to an out building, and goes from there, to the shed via a 10-2 spliced to a 12-2. That wire, in a 4" j-box, with 7 other wires, connects to a 14-3. The black leg runs to a switch and power returns on the red leg to 2 inside lights. The flood light is jumped from the switch and power retuns on the white leg of the 14-3. The wht leg is married in the 4" box to a 12-2 uf wire that runs to the house. The hot switched neutral returns and connects to the rest of the neutrals!
geomac is offline   Reply With Quote
Old 10-10-2012, 04:55 PM   #2
Rewards Points: 1,538
I got lost. Could you draw a diagram?
Old 10-10-2012, 06:24 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Is this a trick question? Because, if it's an old farmhouse......well....it's an old farmhouse....I doubt the plumbing is much better.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
gregzoll (10-11-2012)
Old 10-10-2012, 07:01 PM   #4
Master Electrician
if the hot neutral was connected to the rest of the neutrals you would have a dead short and the breaker would blow.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 10-10-2012, 07:35 PM   #5
Resi EC
Rewards Points: 252
Did it work?
Gac66610 is offline   Reply With Quote
Old 10-10-2012, 07:55 PM   #6
thanks! forum won't let me post replies...
zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
Old 10-10-2012, 08:03 PM   #7
Contractor
Dan101's Avatar
Keyword here which you used several times is OLD. I have seen some real confusing wiring in old homes. Not sure the homeowner is really gonna appreciate the fact that you tore out his floodlights. He may even be the one that wired them. Sounds like it was working and the wires may not be marked correctly. I would suggest marking the wires and looking at it again because it would have caused a dead short if actually wired the way you describe.
Dan101
Owner
J.& D. Remodeling
Chicago, IL
Dan101 is offline   Reply With Quote
Old 10-10-2012, 08:05 PM   #8
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Real intelligent comment. NOT
And you expect help?
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 10-10-2012, 08:47 PM   #9
JOATMON
ddawg16's Avatar
Well....in all honesty, mine was no better.....but then again, not sure what the question was....if there was a question.
Old 10-10-2012, 08:56 PM   #10
Civil Engineer
Rewards Points: 4,856
The question was, "how horrifying is this?". The answer is, apparently, not very. After spending six months inspecting homes destroyed or nearly destroyed by Hurricanes Katrina and Rita on the Gulf Coast, and observing every possible manner of framing errors, electrical errors, plumbing problems, foundation issues, roofing problems etc. in the remains, I can't get too worked up about bizarre wiring in an old farmhouse. The owner, on the other hand, might get worked up over a tenant taking out his floodlights....
Old 10-10-2012, 10:04 PM   #11
Resi EC
Rewards Points: 252
I once did a rewire for a friend who had just bought a house.
In the basement I found a complete loop through 4 j boxes.
It worked fine, but he wanted it rewired, so I opened the main and started cutting.
This is the reason for my question, a simple answer would be 'yes' or 'no'.
horrifying? .. not really ... as long as it works, no telling how many hands have help wire the farm house.
Maybe Geo can enlighten us on how a "farmers 3-way" works.
Old 10-10-2012, 10:04 PM   #12
Electrical Contractor
jbfan's Avatar
Rewards Points: 552
With you living in the old house that you do not own, I'm sure you violated some rule by doing electrical work.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Billy_Bob (10-11-2012)
Old 10-10-2012, 11:08 PM   #13
kevinp22's Avatar
Rewards Points: 252
reminds me of the scene in air force one when harrison ford needs to cut either the red, white, blue or green wire but cutting the wrong one will crash the plane. so he says come on red, white and blue and cuts the green one. whew the engines are still on.
kevinp22 is offline   Reply With Quote
Old 10-10-2012, 11:12 PM   #14
Resi EC
Rewards Points: 252
Never thought of it, but you're right
The Following User Says Thank You to Gac66610 For This Useful Post:
kevinp22 (10-11-2012)
Old 10-11-2012, 05:01 AM   #15
dmxtothemax's Avatar
Rewards Points: 5,508
If you really think it is unsafe ?
Then throw the breaker on that circuit,
Then ask the owner to get it done safely !
But you really should NOT be doing electrical work
in someone else's place .
two wrongs dont make a right !
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
