-   -   how to hook up computer fan with fan speed control to cell phone charger (http://www.diychatroom.com/f18/how-hook-up-computer-fan-fan-speed-control-cell-phone-charger-149736/)
aftermath431 07-09-2012 09:04 PM
im going to be using a gelid wing 8, 12 volt computer fan as a exhaust fan for a kids outdoor playhouse. i know how to hook the fan straight to the 12 volt cell phone charger, but not with the fan speed control that it comes with. here are the color codes of the fan . the fan itself has a red,yellow. and a black wire. that connects into the fan speed control. at the fan speed control it has black, red,yellow.yellow,red.and grey going into the speed control. on the other end of the fan speed control it has a three prong female adaptor where you are suppose to run ever thing to. the color of the three wires at the end of the fan speed control with the three prong female plug in, are adaptor, not sure whats its called has a yellow,red and grey wire. how can i connect this to the two wires on the cell phone charger so that the fan speed control works?
Missouri Bound 07-09-2012 09:25 PM
Trial and error....and it's unlikely the charger has the ampacity to power the fan very long...if at all. Is this a "fun" experiment, because it's not large enough to do anything but spin in anything larger than a tower cabinet. Unless the outdoor playhouse is the size of a picnic basket this really has no potential.
jimmy21 07-09-2012 09:42 PM
39 Attachment(s)
Youre going to have to find out how the fan controller is wired up. I don't think anyone on here will know off hand how it is wired up. The fan itself uses red and black. The yellow isn't used. It is used to tell the computer how fast the fan is spinning. I would suggest just wiring the fan without the fan controller and see if the project will even pan out
aftermath431 07-09-2012 10:02 PM
lost..
thanks i wasn't sure about the yellow. i got the idea from online other people using computer fans for things like grow... rooms, and also sheds. its not to cool down the hole playhouse its just up near a top vent to help get some of the heat out. wish I could figure out how to get the speed control to work with the cell phone charger. to make it more confusing im getting a 12 volt Temperature Control Thermostat so it only turns on when it gets hot. maybe above 80 degress. yea now im really confused. one wire i cant figure out how to get the fan speed control to work.
k_buz 07-09-2012 10:04 PM
How much air do you expect to move with a 5" fan? You'd probably move more air cutting in a roof vent or two.
Missouri Bound 07-09-2012 10:23 PM
It's not going to do anything....period. Grow rooms, outdoor sheds?? I'm sure someone must have installed them...but they do nothing. It's a waste of time. Now if you could install 10 of them, you may notice a difference....just maybe.
jimmy21 07-09-2012 10:25 PM
39 Attachment(s)
depends how big this playhouse is. Some playhouses about about 6 sq/ft with 4 foot ceilings. A computer fan would probably work just fine
Protocol. 07-09-2012 10:54 PM
I would pick up something like a 200MM 12V fan. Would move much more air.
a cell phone charger should provide more than enough amperage to run a fan. An Iphone charger puts out 1A @ 12V, Most you'll see out of a fan would probable be around .2 A. The cell phone charger will list what kind of amperage it is rated to supply. All you'll really need to do is isolate the 12V on the charger and hook it up to the fan.
Missouri Bound 07-09-2012 11:05 PM
1A? Sure it's not .1A? I've looked at my chargers and that's all they've got.
Protocol. 07-09-2012 11:12 PM
Iphones will draw 1 amp. Ipad chargers are rated for 2.1 amps. Now they only put out 5 V, but if he hooked it up, the fan would just run slower.
Missouri Bound 07-09-2012 11:19 PM
Amazing. My cell phone doesn't require that. Now that you mention it, what cell charger does put out 12V?
jimmy21 07-09-2012 11:34 PM
39 Attachment(s)
You should be able to look around and find any old transformer off an old printer or video game console or something. Majority are 12v. You should be able to find one that is close to 1 amp.
aftermath431 07-10-2012 04:21 AM
fan speed control
what about the fan speed control. is there any way to hook that up so it works? the playhouse is only 4x8 foot.
aftermath431 07-10-2012 04:31 AM
cell phone charger says..
it says on it input-120vac, 60hz, 19w. output- 12vdc, 1A .
