How High For Front Light? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2006, 05:58 PM   #1
How high for front light?
Any perfectionists out there?
How high should the light be (from the ground) on the front porch? The door is seven feet tall? I can't put the light next to the door because there are glass blocks on both sides of the door. The glass blocks take up the space up to the side walls. The light will have to be placed on the wall on the right side of the house. The light hook up box looks too low to me. (Can't put a hanging light on the ceiling of the porch because it's sloped with natural wood showing. The outdoor metal piping for the electrical wiring can't be hiden and would look bad.)
I'm sure some of this is personal taste. But, any suggestions are appreciated!!! I can't believe how many details there are with electrical work.
FYI
Yes, I have hired a licensed electrician.
Not Sure is offline   Reply With Quote
Old 08-06-2006, 08:04 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,864
This is an absolutely site specific thing, especially in a case like yours.
For reference I usually put them at roughly 6' 6".
Old 08-07-2006, 12:37 AM   #3
Thank you so much for your reply!!!
I really am glad to get a prof. opinion.
I will measure the light location tomorrow morning. I just feel it is too low. Now, I have a something to go by. I just want to double check things. Once the stucco is up, the light won't be changing. These are the little things that can make or break a house.
Thank you, again.
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Part of a ceiling fan light fixture needs help...please g5729 Electrical 1 06-17-2007 07:22 AM
Red & Black wire from light = blown fuse leedslad Electrical 3 08-28-2006 07:54 PM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 08:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
