How Hard Is It To Install A Standby Generator? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-24-2012, 11:44 AM   #1
How hard is it to install a standby generator?
I want to install a 20KW Kohler natural gas standby generator - is this a viable DIY project or should I be very afraid of blowing up my house?
Alternatively how much would one expect to pay for an electrician to do this? I'm located in Fairfax County, Northern VA. I have a location picked out within 10ft of the gas meter and main electrical panel. Would the electrician handle the gas hookup as well, or is this a job for a plumber?
aljagre is offline   Reply With Quote
Old 08-24-2012, 12:25 PM   #2
Rewards Points: 150
I can PM you the name/number of a licensed electrician, if interested. He's not the fastest, and you get scheduled around his commercial work, but his workmanship is top notch and his prices are fair.
silversport is offline   Reply With Quote
Old 08-24-2012, 02:01 PM   #3
Thank you - that would be a great help!
Old 08-24-2012, 04:58 PM   #4
Master Electrician
i wouldn't recommend a genny instal for anyone that isn't serious about DIY, or someone who's willing to make a lot of mistakes learning how to do it right. If your questioning whether your skills are adequate then you can maybe ask the electrician to do the main connections and ask for some savings if you do some of the grunt work.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 08-24-2012, 05:19 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,968
I would NOT consider a 20kW standby unit to a DIY job for anything but the most advanced DIYer. Even then I question it.
Prices are a very subjective thing, but considering the close proximity you will be on the lower end of things. A typical electrician will NOT do the gas piping.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
frenchelectrican (08-24-2012)
Old 08-24-2012, 06:34 PM   #6
Licensed electrician
Rewards Points: 1,742
I agree with Speedy. Also your gas meter may need to be upgraded.
Old 08-24-2012, 06:46 PM   #7
Rewards Points: 13,956
Going to have to get gas and electrical permits to do it.
Even where it's going to be has to meet code.
Old 08-24-2012, 06:47 PM   #8
Missouri Bound's Avatar
You can do a few things necessary for the installation. You can level the site and pour the slab. If so inclined you can purchase the equipment. The installation itself is better left to someone with the experience and knowledge to safely handle entrance equipment. Safety is the biggest part of these installations. I take it you will be using it for the entire home?
Do you want it your way or the right way?
Old 08-24-2012, 07:10 PM   #9
Possibly even the line from the street as well.
Old 08-24-2012, 09:54 PM   #10
dmxtothemax's Avatar
Rewards Points: 5,478
You might be able to do some of the grunt work !
But I would leave some of it up to a tradesman !
Perhaps speak to a tradesman first,
and find out how much you can do,
he can then advise you, how to do it proper.
And up to code !
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Missouri Bound (08-24-2012)
Old 08-24-2012, 10:32 PM   #11
Rewards Points: 150
PM failed. Said you were not accepting or were not allowed to receive PM's.
The Following User Says Thank You to silversport For This Useful Post:
aljagre (08-26-2012)
Old 08-24-2012, 11:22 PM   #12
" Euro " electrician
frenchelectrican's Avatar
I think it have to be over 10 posting before the PM can be actived but not sure on the DIY fourm rules per using the PM. ( you can check with Moderators they can assit you on this matter )
Merci,
Marc
Old 08-25-2012, 06:55 AM   #13
That is "advanced" electrical work. I would recommend getting an electrician who is experienced with the installation of generators and of course get electrical and other permits needed.
Some of this stuff is mind boggling even to experienced electricians. Google the following words for example...
separately derived system generator
and...
gfci generator transfer switch
and...
gfci generator OSHA
and...
generator backfeed danger
Billy_Bob is offline   Reply With Quote
Old 08-25-2012, 07:23 AM   #14
Rewards Points: 3,130
You must also consider whether it is even legal in your location for you to do the electrical and gasline work. In many places, it is not unless you're a licensed contractor.
I am an experienced DIYer (wife and I built our house essentially by ourselves) and I would not tackle this project. The electrical maybe, but never the gas. While I plumbed our house myself and installed the gas tankless water heater, I paid the propane supplier to run the gasline. It was less than $100.
Old 08-26-2012, 08:53 AM   #15
Rewards Points: 348
I did a 17kw. Andrew is correct about being willing to make, while I won't call them mistakes, corrections and changes as you go along. The manual assumes you have 1) space behind the panel location (or withing 30') for the generator and 2) space right beside the panel for the transfer switch. That is usually not the case.
I did it all including running 150' of gas line. But I started pipelining as teen so that part was easy. Took me a good 2 weeks (not full-time) and reconfigured things a couple of times, but it is good to go now. Had a master electrician (neighbor) come up and inspect it and the only thing he dinged me on was taping some of the wires together in the box.
But I also had to reconfigure the transfer switch. I did not need 3 240 circuits. So 2 of them got removed which involved adding neutrals for their replacements and replacing a couple of the breakers with AFCI's.
I plan on posting pics when I get a chance to download them. If I had it to do all over again, I would probably borrow the requirement from our neighbors to the north and to all the wiring in an external box.
herdfan is offline   Reply With Quote
standby generator masanori Electrical 0 02-16-2012 02:43 PM
Generator connection Question - Final Plan Apollo67 Electrical 24 01-30-2012 07:44 PM
Whole House Standby Generator captnron Electrical 3 12-13-2011 07:35 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Hard wood floor install help helpless handyman Flooring 13 06-04-2007 08:12 PM
