How To Ground A Weather Station - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-25-2012, 01:23 PM   #16
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If I was going to be installing something that expensive I would check with a local inspector what they require for your area. Some number 4 insulated wire to a couple copper rods would not cost that much to be on the safe side. And the unit should also but properly grounded when connected to the power.
We had an antenna at our home when I was a kid that had a fairly large ground from the mast to a rod and it also had a motor that was grounded inside. I am not sure if it was bonded to or isolated from the mast ground. And I also added a grounding block inside before the cable went to the signal amplifier and splitter.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-25-2012, 02:44 PM   #17
wareagle's Avatar
The size of the conductor does not really make a big difference. At the frequency of the strike, the impedance of the conductor is about the same for #6 thru 4/0 copper. Also it is not necessary that it be insulated.
If the op decides to install several ground rods, I would space them at least 2 x the length of the rod.
wareagle is offline   Reply With Quote
Old 03-25-2012, 04:30 PM   #18
joed's Avatar
Rewards Points: 12,862
I think you have two separate concerns. Grounding/bonding the system and Lightning protection with proper air terminals. These are two separate issues.
The Following User Says Thank You to joed For This Useful Post:
mpoulton (03-26-2012)
Old 03-25-2012, 06:38 PM   #19
Master Electrician
Rewards Points: 3,870
Originally Posted by Jim Port View Post
The nerve of those guys charging for their services and knowledge.
Yeah, but he can afford a $2800.00 unit.
brric is offline   Reply With Quote
The Following 2 Users Say Thank You to brric For This Useful Post:
gregzoll (03-25-2012), Speedy Petey (03-25-2012)
Old 03-25-2012, 07:26 PM   #20
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
HAHAHA, good point. I never looked at the unit in question.
A $2800 weather station (for volunteer work no less) is affordable, but ~$250 to ground it properly is an arm and a leg.
Priceless.
Old 03-26-2012, 09:46 PM   #21
joed's Avatar
I guess he didn't like what he heard here.
http://www.mikeholmesfanforum.com/ph...hp?f=3&t=48693
Speedy Petey (03-26-2012)
Old 03-26-2012, 10:11 PM   #22
Rewards Points: 6,652
So, if you go around Spamming other forums due to you did not like the answer you got on one of the others, does that change the response in doing it properly, as we have already stated?
I know, they expect the answer to change and if they do not like the new answer on the Mike Holmes Forums, they are going to probably show up on DSLReports Home/DIY forum and try to do it all over again.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 03-27-2012, 07:42 AM   #23
joed's Avatar
Well at least now we know where they live. The MH forums will give the proper answer for Ontario. It is mostly a Canadian based membership.
Old 03-27-2012, 10:14 AM   #24
rrolleston's Avatar
Reminds me of this thread. I found a link to it on another forum. The guy just kept going around asking till he got the answer he wanted from who knows where.
Unsafe Panel
Once he does the hack weather station install and something happens probably void the warranty that thing will even be worthless as a boat anchor because it's too light.
Fried electronics after earth ground accidentally disconnected oukachiru Electrical 7 07-12-2011 03:05 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 01:04 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 04:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 03:26 PM
