How To Ground This Old Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 03:17 PM   #1
Rewards Points: 113
how to ground this old wire?
I redoing part of my kitchen, some of the drywall have been removed. I'm looking at the NM cable that goes to a wall outlet, it has only 2 wires (no ground.) what is the easiest way to add grounding to this. can I just ground it to my copper water pipe? If so, I can just wire between the ground receptacle of the outlet and the copper pipe? (I'm hoping not to replace the entire length with new wire.) thx
oldhouse49 is offline   Reply With Quote
Old 01-14-2012, 04:05 PM   #2
jproffer's Avatar
Rewards Points: 706
You can't just attach to a pipe.
Under some circumstances, you can ADD a seperate ground. But if the wall is already open, it would be just as well to pull new xx-2 down to the panel.
I'm assuming if it's one of the kitchen rec.'s, it's 12-2.....
Must be really old wire to not have a ground included.
jproffer is offline   Reply With Quote
Old 01-14-2012, 04:09 PM   #3
MarginallyQualified
Rewards Points: 2,464
So much for hoping.
You're kitchen remodel job expanded to re-doing the wiring.
You'll need 12/2 NM and some TR GFI's, probably more boxes than you have now and very likely some new circuits too.
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 02:29 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
