How To Ground A 2-wire Outdoor Lamp Post Elect. Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 05:00 PM   #1
How to ground a 2-wire outdoor lamp post elect. outlet
MY HOUSE WAS BUILT IN 1952. I just replaced the outlet that attaches to the lamp post. However, in doing so I found that it has only 2 wires coming from main electrical service (not surprised considering age of house). Is there a way to ground these older outlets so they can be used with outdoor power equipment? Can the outlet be grounded to the lamp post itself on the inside?
Also, my outlet tester shows that the hot and neutral are reversed yet the lamp post outlet works fine. Is this normal that the outlet still has power to light my trouble light even if hot and neutral are reversed? What is the danger of leaving it the way it is? I wired the black from house service to the black wire on the outlet itself.
Thanks for your help.
numbersguy is offline   Reply With Quote
Old 09-22-2012, 05:20 PM   #2
Code05's Avatar
Rewards Points: 1,104
Use GFCI receptacles or breakers. That is legal and brings them to modern code. Outside receptacles require GFCI protection. GFCI receptacles do not require a ground wire to work correctly.
DO NOT GROUND TO LIGHT POST, ILLEGAL!!!
Reverse wired incandescent fixtures will operate, but are dangerous. Rewire correctly.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
numbersguy (09-23-2012)
Old 09-23-2012, 08:16 AM   #3
GFI for lamp post?
Code05, do they sell GFI's for outdoor lamp posts? It needs to curve around the pole. Also, what about my second question. Can you help me with that?
Old 09-23-2012, 08:29 AM   #4
reversed hot and neutral wires
Never mind Code05, i now see your answer under a quote of my question. Thanks.
Old 09-23-2012, 09:06 AM   #5
Rewards Points: 150
SNIP
Many devices "don't care" which line is hot and which line is neutral, so long as there's a difference of 120VAC between the two. Think of all the small appliances that just have two-prong plugs.
At one time, it was normal for outlets to have just two rectangular sockets (no ground pin), and both sockets were the same size. Appliances, lamp cords, etc. could be plugged into these sockets either way. Should there be some sort of problem in the device (insulation failure, for example), 120V could be present on the case of the product (which in those days was almost always metal, not plastic).
So somewhere along the line (50s, 60s, 70s?), the code was changed. The round ground pin was added, and one pin on the plug was made larger, so the plug could only be inserted one way.
Dave632 is offline   Reply With Quote
50 Amps for a garage help IcyShadowz Electrical 48 05-31-2012 11:58 PM
Ground rod and ground wire question mulltron Electrical 17 07-29-2011 06:10 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Outlet neutral bonded to ground? rjniles Electrical 1 07-19-2008 12:12 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
