How To Ground? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-21-2012, 10:47 AM   #1
How to ground?
I made myself a conductive wristband for working with esd sensitive objects and was wondering what to connect the end of the wire to (other them the ground hole in the wall plug and the chassis of whatever i'm working on)
Kolby is offline   Reply With Quote
Old 07-21-2012, 01:30 PM   #2
Rewards Points: 1,520
plumbing should be grounded assuming not pex and properly installed.
bob22 is offline   Reply With Quote
Old 07-21-2012, 01:33 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Im curious what you wanted to hook it up to?
Old 07-21-2012, 02:32 PM   #4
Master Electrician
A regular purchased static wrist strap just hooks to the device chassis. That's as far as you need to go with it. It's not about grounding the static its about keeping your potential the same as what your working on and preventing a static arc.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
mpoulton (07-21-2012)
Old 07-21-2012, 08:53 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,852
As Andrew says, the "grounding" strap doesn't need to actually ground you. It's really an equipotential bonding strap. You just need to ensure that you are at the same potential as the static sensitive parts. Connecting to the equipment you're working on is all that really matters.
mpoulton is online now   Reply With Quote
Old 07-21-2012, 09:20 PM   #6
Rewards Points: 3,256
I feel that I need to add some cautions here. Since you made your own I'm not sure what that really means. Proper wrist straps have megohms of resistance so you don't electrocute yourself. I would suggest buying a wrist strap....they're not very expensive.
A conductive mat for the bench would be a nice addition if you work with PC boards a lot.
zappa is offline   Reply With Quote
Tags
boobs , esd protection , ground , monsters
To ground or not to ground Red Squirrel Electrical 2 10-14-2010 09:42 PM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 09:40 AM
Electrical Ground Problem cabinetman Electrical 15 01-28-2010 05:55 PM
Live ground wire in dryer Retired sailor Electrical 10 05-04-2009 04:26 PM
Hot Tub Install--Grounding Rod Question statgeek_rob Electrical 16 09-15-2007 03:59 AM
