How to ground?
I made myself a conductive wristband for working with esd sensitive objects and was wondering what to connect the end of the wire to (other them the ground hole in the wall plug and the chassis of whatever i'm working on)
plumbing should be grounded assuming not pex and properly installed.
A regular purchased static wrist strap just hooks to the device chassis. That's as far as you need to go with it. It's not about grounding the static its about keeping your potential the same as what your working on and preventing a static arc.
As Andrew says, the "grounding" strap doesn't need to actually ground you. It's really an equipotential bonding strap. You just need to ensure that you are at the same potential as the static sensitive parts. Connecting to the equipment you're working on is all that really matters.
A conductive mat for the bench would be a nice addition if you work with PC boards a lot. |
| All times are GMT -4. The time now is 10:59 PM. |
