How To Get More Reds And Yellow Out Of A Incandescent Light Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 05-01-2012, 01:01 PM   #1
how to get more reds and yellow out of a incandescent light bulb
I'm using very bright incandescent lights through chickens lamps to increase my metabolism. The reds and yellows that come out of incandescent bulbs do this. My question is how can I increase the production of reds and yellows? Is there anyway I could change the wiring in the chicken lamp to force it to produce more reds? I heard that putting a 130 volt bulb in a 120 watt socket will produce more reds? Any other ideas of mods I could do to the lamp? I was also wondering if red heat lamps produce more reds and yellows then regular incandescent light bulbs or do red heat light bulbs just have red coated paint which makes them appear like their producing more red?
ahrealy is offline   Reply With Quote
Old 05-01-2012, 02:01 PM   #2
I=E/R
a7ecorsair's Avatar
This increase is for you or for chickens?
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
gregzoll (05-01-2012)
Old 05-01-2012, 02:04 PM   #3
this is far out, man, far out
itsnotrequired is offline   Reply With Quote
The Following 2 Users Say Thank You to itsnotrequired For This Useful Post:
gregzoll (05-01-2012), operagost (05-01-2012)
Old 05-01-2012, 03:31 PM   #4
Rewards Points: 13,446
Any of the Revel light bulbs will do what your asking.
http://www.gelighting.com/na/home_li...reveal_cfl.htm
Old 05-01-2012, 05:04 PM   #5
thank you joecaption but it says that they are specially made to filter out the dull yellow rays? How is this better then original incandescents?
Old 05-01-2012, 05:49 PM   #6
If you want a true natural light that almost the same as sun light it's the way to go.
Old 05-01-2012, 05:55 PM   #7
Plant grow lights. Or in the dimmer recesses of the inter-webs, "grow" lights.
Seriously though. What you need to tell us is if you are battling SADS in which case you are mostly looking for more lumens generally. Or if you are trying to make up for something like a vitamin D deficiency, in which case you want full spectrum. But supplement tablets are cheaper...
Evstarr is offline   Reply With Quote
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
